blitz sbc gain
Old Jan 2, 2006 | 06:41 PM
Midnyte's Avatar
Midnyte
Default blitz sbc gain
I just installed my blitz sbc id on my turbonetics kit. I set the channels to auto and dialed in my desired psi. I also changed the configuration from actuator to wastegate. What should the gain be set to? I know a higher setting will attempt to hit the target boost sooner, but has anyone actually tested varied configs? The instructions only say about setting between 5-15 for an actuator, but suggest higher for wastegates. I'm not sure just how much higher they are suggesting.
Looking for some experience...
-Blaise
Old Jan 2, 2006 | 07:02 PM
tig488's Avatar
tig488
-Blaise
as phunk told me, put it on manual, i have mine on manual, set to 80, gain at 30. and mine is also on WG.
Old Jan 2, 2006 | 07:26 PM
Midnyte's Avatar
Midnyte
so 30 is working without giving any boost spikes for you? I was curious because I didnt want to set it too high and have probs.
Old Jan 2, 2006 | 07:28 PM
tig488's Avatar
tig488
well, on mine it isnt, i have the APS ST, not the TN. be careful, the kits are very different, i dont want you to do what i do and cause damage, just keep an eye out and set the limiter to whatever you think is needed to be safe.
Old Jan 3, 2006 | 08:55 AM
MIAPLAYA's Avatar
MIAPLAYA
Start with the gain set very low....slowly increase after each run till you get the best boost response. When you start seeing more boost then you set in auto mode you have gone to far and need to back it down... Tig I'm curious why you have yours set to wastegate, I thought it might not work right if you have an actuator and use it in wg mode...
Old Jan 3, 2006 | 11:55 AM
tig488's Avatar
tig488
well i tried it both ways, and wg seems to work the best.
Old Jan 3, 2006 | 12:02 PM
mcderns's Avatar
mcderns
You should be in manual mode not auto. I believe I have my gain at about 80, and my set around 18. I cant remeber, its been over am onth since I was in the car. But just start low, and gradually increase untill you find the spot you like.
Old Jan 3, 2006 | 12:17 PM
tig488's Avatar
tig488
i use manual mode, but gain at 80, woah. my set is 80, and gain is 30.
Old Jan 3, 2006 | 03:53 PM
Midnyte's Avatar
Midnyte
my turbonetics kit hits right at the dialed in boost with a gain of 27. Just figured I'd post the update. If I go any higher, the peak boost is higher then my target.
-Blaise
Ace2347
Sep 22, 2015 03:12 AM
VR3
Dec 11, 2002 08:16 PM
deviousZ
Nov 7, 2002 05:31 PM
