My Turbonetics Set Up (Version 1.25)
Old Jan 8, 2006 | 12:51 PM
Ten to Four Z's Avatar
Ten to Four Z
Exclamation My Turbonetics Set Up (Version 1.25)
With this set up, could I see 450 RWHP Safely?
Will all this work together?
Turbonetics Stage 1.25:
Turbonetics 60-1 Stage V ceramic ball bearing turbo
Spearco FMIC (do they all come with that blue logo sprayed on them)
Evolution Wastegate (with atmospheric dump and down pipe block off)
Raptor BOV
Drop in plug in 510 cc injectors
Walbro 255 lph fuel pump
All piping
Case of TS-1 oil
Extra Goodies:
APS Oil Pan (will this work with the Turbonetics oil return line)
APS fuel return (will this be ok)
UTEC with MAP sensor (boost controller)
Kinetix SSV Or SFR Or B-Line Intake Manifold
Motordyne Gasket
SARD Thermostat
Agency Power Ti 3in Exhaust
B-Line Oil Cooler
KJR Lightweight Stock-Size Crank Pulley
Old Jan 8, 2006 | 12:54 PM
MIAPLAYA's Avatar
MIAPLAYA
Raptor BOV
All piping
Case of TS-1 oil
Extra Goodies:
Motordyne Gasket
SARD Thermostat
B-Line Oil Cooler
Yes they all come with the Spearco logo but it can be flipped around to hide it if you want...it flows the same both directions...
Yes it will work with the oil return...
Yes it will be ok
All in all good setup. Should make some nice numbers..
Old Jan 8, 2006 | 01:13 PM
Ten to Four Z
Thanks you for your input MIAPLAYA.
Does anyone have any other sugestions to my setup?
Maybe some thing I missed.
Yes it will be ok
Old Jan 8, 2006 | 02:51 PM
JETPILOT's Avatar
JETPILOT
Raptor BOV
All piping
Case of TS-1 oil
Extra Goodies:
Motordyne Gasket
SARD Thermostat
B-Line Oil Cooler
To simplify things here....
TN Tuner Kit
510 injectors Why not 550?
APS Oil Pan What problem are you solving with this? Just get an AAM pan spacer.
APS fuel return Or AAM
UTEC with MAP sensor Add BCS solenoid
Kinetix SSV Or SFR Or B-Line Intake Manifold Not neeeded for 450whp
Motordyne Gasket
SARD Thermostat
Agency Power Ti 3in Exhaust Might cause overboost problems with Evolution wastegate.
B-Line Oil Cooler
KJR Lightweight Stock-Size Crank Pulley Not needed fot 450 whp
Old Jan 8, 2006 | 02:55 PM
MIAPLAYA's Avatar
MIAPLAYA
TN Tuner Kit
Motordyne Gasket
SARD Thermostat
B-Line Oil Cooler
The 510s will drop in and plug in. Assuming hes using Denso 510s they are good to AT LEAST 550..
Old Jan 8, 2006 | 02:56 PM
JETPILOT's Avatar
JETPILOT
What other sizes does Denso make? Are they all plug and play?
Respect
JET
Old Jan 8, 2006 | 02:57 PM
MIAPLAYA's Avatar
MIAPLAYA
Respect
JET
So far the only ones I know of are 380 and 510 but they are both plug any play. I imagine if PE has a bigger size then so does Denso (same manufacturer there) So basically whatever size PE has you can get in a Denso plug and play..
Old Jan 8, 2006 | 03:22 PM
JETPILOT's Avatar
JETPILOT
Where can I get the 510's? Those are the brand TN uses?
Respect
JET
Old Jan 8, 2006 | 03:26 PM
Ten to Four Z
Thanks for the insight JETPILOT.
TN Tuner Kit
510 injectors Should I just get the full APS High Energy Fuel System (550's)
APS Oil Pan More Oil-Cooling Fins-Baffles
APS fuel return
UTEC with MAP sensor Add BCS solenoid (What Brand)
Kinetix SSV Or SFR Or B-Line Intake Manifold I just like the looks
Motordyne Gasket
SARD Thermostat
Agency Power Ti 3in Exhaust Which wastegate should be used to cure overboost
B-Line Oil Cooler
KJR Lightweight Stock-Size Crank Pulley I figure it MIGHT help Spool Up
Old Jan 8, 2006 | 03:40 PM
down_shift's Avatar
down_shift
Agency Power TI? Pics and link please
Old Jan 8, 2006 | 03:42 PM
MIAPLAYA's Avatar
MIAPLAYA
Respect
JET
You should be able to get them from Turbonetics or a vendor...the 510s are what Turbonetics is including in the Stage 1.5 upgrade..
Old Jan 8, 2006 | 03:43 PM
JETPILOT's Avatar
JETPILOT
I imagine they will also work with the AAM fuel rails?
Cost?
Respect
JET
Old Jan 8, 2006 | 03:45 PM
MIAPLAYA's Avatar
MIAPLAYA
I imagine they wil lalso work with the AAM fuel rails?
Cost?
Respect
JET
Yes they will as the AAM fuel rails are compatible with even stock injectors... As for price not sure honestly... Best bet would be to call Reggie or a Turbonetics vendor and see what they have pricing wise. I know PE overcharges BIG TIME for their version. Turbonetics may be better priced..
Old Jan 8, 2006 | 04:19 PM
Ten to Four Z
Agency Power Ti Catback Exhaust
Pictures And Video (You can even finance it for 90 days)
http://www.vividracing.com/catalog/p...ducts_id/13102
Old Jan 8, 2006 | 07:22 PM
JETPILOT's Avatar
JETPILOT
Raptor BOV
All piping
Case of TS-1 oil
Extra Goodies:
Motordyne Gasket
SARD Thermostat
B-Line Oil Cooler
I didn't see your choice for a clutch/flywheel. Any plans?
In my opinion the APS oil pan is not worth the cost. The AAM oil spacer provides an oil return silution and increases oil capaity by one quart. It costs about $200 and comes pre-drilled for the oil return with all the AN fittings and hose you need.
As far as the overboost problem TN is working on a solution. The problem is the inneficient mounting of the wastegate. Likely not the wastegate itself.
BCS.... your choice. I like the Turbosmart boost control solenoid.
APS fuel system. I am familiar with the AAM. I don't know anything about the APS.
Yes.. you will likely have problems with that exhaust with overboosting. It seems very effiecient.
Respect
JET
Old Jan 9, 2006 | 05:59 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
I suggest the CJM or AAM fuel return systems. cj-motorsports.com for the CJM or talk to Sharif for the AAM.
Old Jan 9, 2006 | 01:32 PM
D350Z10's Avatar
D350Z10
If you want 450 whp
Tunner TN KIT
RC 550 Injectors
AAM Fuel Return
Utec with Map sensor/ Map switch/ tuner/ GM solenoid
Crawford Plenum
Any Single 3in Exhaust... I perfer HKS
Kjr Pulley for faster acceleration
**** IF YOU WANT... WELL WORTH it for power Headers.... Alphaworks fit
@9.5 psi you should be perfect.
Cooling:
Koyo Radiator and Nismo Thermostat
Old Jan 9, 2006 | 03:00 PM
Ten to Four Z
D350Z10 is this your setup?
The koyo fits with the TN kit?
How do headers benifit this kit? (better spool up, better flow)
How about over boosting, will the evolution wastegate be ok even with an atmospheric dump at 9.5psi?
Originally Posted by D350Z10
If you want 450 whp
Tunner TN KIT
RC 550 Injectors
AAM Fuel Return
Crawford Plenum
Cooling:
Old Jan 9, 2006 | 03:32 PM
JETPILOT's Avatar
JETPILOT
Ten To Four Z......
Respect
JET
Old Jan 9, 2006 | 03:34 PM
JETPILOT's Avatar
JETPILOT
No it won't. Atmospheric dump didn't change anything as far as overboosting as per Kcobeans attempt. 62F I was boosting 12.5 psi.
Respect
JET
