Hondata Heatshield Gasket 350z and G35
Old Feb 10, 2006 | 03:10 PM
CpraceZ's Avatar
CpraceZ
Default Hondata Heatshield Gasket 350z and G35
Yes these things work I have been a Hondata Dealer for years and have seen nothing but good things from these Gaskets amazing changes in temps gaskets and its great that they are now making them for the Zs if anyone is interested in purchasing this product feel free to PM me.
Hondata have developed a special high temperature insulating gasket which replaces the stock intake gasket. This and bypassing several heat sources significantly reduces the transfer of heat from the head to the intake and incoming air giving you up to 5% more power.
Turbocharged cars often use an aluminum intercooler to cool the air compressed by the turbo. The intake manifold is also made of aluminum but because it is heated by the head from combustion and coolant, works in reverse to an intercooler by heating the intake air by as much as 50° C.
Fact: For every 3.3 °C (5° F) rise in intake temperature, air density drops 1%. The hotter the air, the less fuel the computer injects to compensate for reduced oxygen. HondaLogger datalogging software has enabled us to measure intake air temperature under varied driving conditions.
Around town, testing has shown an average drop of around 10 degrees C which is good for around 3 percent power increase. Remember though that 3 percent power increase is difficult to feel. You'd feel a greater change in performance getting rid of that passenger. In certain conditions a 30° C drop has been measured.
The Honda manifold is heated in up to 5 places. From the head, the interior heating takeoff hose, the cold idle valve, the idle control valve and the throttle body heater. The Heatshield gasket kit contains an insulating gasket, and installation instructions. A race version only version with the thermostat bypass blocked is also available
The graph above shows the results of installing the Heatshield gasket and bypassing the throttle body heating and idle control valve heating. If you examine a Type R intake manifold you will find that most sources of water heating are removed. Further temperature drops are possible when in addition the interior heating hose is blocked. What the graph shows, is that as you open the throttle, the intake temperature drops slowly as it cools the intake. When you descend a hill with the throttle closed or drive around town on a light throttle the temperature climbs quickly. It takes a good 15-20 seconds for the temperature to drop again when you open the throttle. So if you start your 1/4 mile drag with a hot intake manifold - you are only starting to develop maximum power near the end of the run when the intake has been cooled. The Heatshield gasket kit gives you 4-5% more power immediately by lowering the intake temperature.
Old Feb 10, 2006 | 03:18 PM
CLETUS's Avatar
CLETUS
i have seen the ads saying they make gaskets for other makes now. whats teh price???
Old Feb 10, 2006 | 03:20 PM
Tsex On 19s's Avatar
Tsex On 19s
I used to have one for my old car.. didnt really make a difference, never dyno'd before and after, only thing i can say is the car felt much smoother.
Old Feb 10, 2006 | 03:38 PM
DavesZ#3's Avatar
DavesZ#3
I had been in contact with somebody at Hondata for what seems like a year ago about these, they were testing them at the time. Motordyne beat them to the 350Z scene with the Isothermal kit several months ago. It definitely keeps the intake temperature about 25 to 30ºF cooler. 30ºC seems a little extreme if you ask me.
Old Feb 10, 2006 | 03:43 PM
CpraceZ's Avatar
CpraceZ
I sell the for $50.00 we have had these on many cars and seen a big change
Old Feb 10, 2006 | 05:24 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I have the setup made by Nippon
Old Feb 11, 2006 | 08:01 AM
CpraceZ's Avatar
CpraceZ
Haven't tried any of the other brands that are out there, I know from experience that the Hondata gaskets work, and would be a great mod for anyone with FI
JjL
East Canada
Jun 12, 2019 03:04 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
