CEL Codes
Old Mar 5, 2006 | 08:58 PM
MIAPLAYA's Avatar
MIAPLAYA
Here is a pic of the newer downpipe with the O2 extensions. Note that the third bung is not normally there. It was added for a wideband. What you are looking for is that your downpipe has those two extensions for the secondary O2 sensors:
Old Mar 5, 2006 | 09:05 PM
lucidazn's Avatar
lucidazn
Yeah, that's my picture xP
There was a TSB a while back from Nissan regarding the CEL being thrown by the O2. The only to fix it if you have the downpipe with the extensions is to take the car to Infiniti, apply the TSB, then send your ECU back to Turbonetics to be reflashed again.
What does this TSB actually do? Can I still get the TSB free even with the turbo? I'm not understanding what is going on here. Why are the codes coming up? What will the TSB do? Why will the TSB fix it? Why do I need to send in my ECU again?
Old Mar 5, 2006 | 09:09 PM
MIAPLAYA's Avatar
MIAPLAYA
Yeah I know I just jacked it from your thread. Hope you don't mind. I don't have any good pics of mine.
Old Mar 5, 2006 | 09:13 PM
MIAPLAYA's Avatar
MIAPLAYA
The TSB is for the ECU incorrectly throwing the 1274 code. Its happened to a few people already. The TSB is that the dealer re-flashes the ECU with different parameters for its detection of the O2 voltage. The ECU then has to be sent back to Turbonetics to have the tuning part re-done for the turbo. Having the kit does not stop you from being eligile to have the TSB work done.
Old Mar 5, 2006 | 11:06 PM
lucidazn's Avatar
lucidazn
Damn, I was afraid you were going to say that.. =/
Old Mar 6, 2006 | 06:28 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Thanks Rob.
I do not have those o2 extensions.
Old Mar 6, 2006 | 06:37 AM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by 35ounces
Thanks Rob.
Gotcha, in that case call Reggie and he can overnight you a replacement downpipe with them in there.
Old Mar 19, 2006 | 03:22 PM
G3.5T's Avatar
G3.5T
Did you finally get these codes resolved??? I have the exact same 2 codes, P1274 and P1283 after my TN S/T kit install. I am racking my brain trying to find out how to fix it. I have the new version with the extensions on the downpipe and I still have these codes. Funny, TN said they haven't run into this problem before but clearly someone else has the exact same problem as me.
Old Mar 19, 2006 | 03:26 PM
lucidazn's Avatar
lucidazn
No i keep getting them
Old Mar 19, 2006 | 03:30 PM
G3.5T's Avatar
G3.5T
Has anyone told you it is something to worry about? I can't imagine it is good. What mods do you have besides the turbo?
What about Jet Pilot? Find a solution?
Old Mar 21, 2006 | 07:42 AM
jlimquest's Avatar
jlimquest
Default Pictures please....
I remember seeing them & now their gone.....please re-post...Thanks, Jeff
Old Mar 21, 2006 | 07:44 AM
MIAPLAYA's Avatar
MIAPLAYA
They are in my reply that you quoted...
Old Mar 21, 2006 | 08:11 AM
jlimquest's Avatar
jlimquest
sorry for some apparent reason...it did not show on my screen the first time....Thanks!!!
Old Mar 30, 2006 | 06:17 PM
G3.5T's Avatar
G3.5T
Anyone have any updates on the P1274 and P1283 codes with their TN S/T? I've tried a bunch of different things that were suggested but still no luck.
Old Jul 28, 2006 | 03:33 PM
lucidazn's Avatar
lucidazn
I had to dig this up.
I am unable to get an inspection because of these codes. Since they throw the CEL, I can't pass. So, I tried clearing them before going in, which didn't work. On the computer, it says my evap, and o2 are in a NOT READY status. Which means I cleared it before I went in for inspection. So I had to drive it around for the systems to be 'turned on'. After 45 miles or so, I went back in, the systems haven't turned back on, and he let me go withiout paying for the failure. Then after some more driving, the lights were thrown again. I will not be able to pass unless I remedy this.
What should I do with these damn codes? Really pissing me off...
PS I have the extension to the o2 sensors
Old Jul 28, 2006 | 03:54 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
did you check to see if the o2 sensors were accidentally swapped OR damaged during install?
Old Jul 28, 2006 | 04:35 PM
lucidazn's Avatar
lucidazn
Yup checked with Nissan Consult. Everything's fine.
Old Aug 1, 2006 | 07:53 AM
  #38
lucidazn's Avatar
lucidazn
*bump
Anyone with a fix? Mia? I need an inspection sticker =/
Old Aug 1, 2006 | 08:47 AM
  #39
MIAPLAYA's Avatar
MIAPLAYA
*bump
Try swapping the positions of the rear O2 sensors...
Old Aug 1, 2006 | 10:14 AM
  #40
lucidazn's Avatar
lucidazn
Thanks, I'll give that a shot.
