Tune safe?
Old Mar 20, 2006 | 01:09 PM
zeer0's Avatar
zeer0
Default Tune safe?
Hey guys,
I just got my car tuned this past weekend at Henderson Performance. They seemed really knowledgeable and nice, but I'm a little concerned about the results after browsing through people's dyno results. These guys mostly work w/ vettes and have only done 3 350's up till my G. They said 12.5 to 11.5 is a good range for AFR and anything lower is probably too rich. I see that most peoples dyno AF's are around 11-12. The dyno sheet below shows AF's around 13:1, but we did the tune off my wideband which was showing low 12's high 11's up till redline where it dipped into the 10's. Should I be concerned about this and go in for a retune? The pull was done in 4th by the way.
http://us.share.geocities.com/danieljlau/DSCF0613.JPG
Old Mar 20, 2006 | 01:12 PM
zeer0's Avatar
zeer0
Wideband sensor is after the main cats by the way, if that makes any difference
Old Mar 20, 2006 | 01:14 PM
chimmike's Avatar
chimmike
why the holy hell would you put the wideband AFTER the cats?
btw, I'd NEVER, EVER go above 12:1 on forced induction.
Old Mar 20, 2006 | 01:34 PM
zeer0's Avatar
zeer0
couldn't find a place with good clearance to put in sensor upstream
Old Mar 20, 2006 | 02:56 PM
zeer0's Avatar
zeer0
I remembered the guys there actually lowered the AF after that final run because I told them I was going from 93 back to 91 octane later on. I tried a couple runs and its all between 11-12 during boost. I guess I'm safe for now until I go back to 91 octane.
Old Mar 20, 2006 | 03:47 PM
backagain's Avatar
backagain
link doesnt work buddy
Old Mar 20, 2006 | 04:33 PM
zeer0's Avatar
zeer0
wierd, i think you gotta copy the link and paste it in the address for it to work.
Old Mar 20, 2006 | 05:02 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
link still doesnt work
13:1 on a F/I car is wayyyyy too lean...I tune to 11.4-11.8:1
You need to be very cautious with what you are describing here...get a link that works so we can see the dyno and then you'll get some better feedback
TODD
Old Mar 20, 2006 | 07:33 PM
zeer0's Avatar
zeer0
Hmmm... i think cause the files too big The dynojet sniffer was reading just under 13 but my aem wideband was reading lower.
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
