Driveshaft question.
Old Mar 31, 2006 | 09:58 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Default Driveshaft question.
Ok, its not so much a question as it is a carification. From what i gather, the stock driveshafts brake up at around 400whp, but only really if you put drag radials or slicks on their, and you take the car to the drag strip. So i'm looking at only going as wide as 285 in the rear with some toyo T1R, theoretically i should be safe to run the stock driveshafts? I also understand about the "shock" factor on the shaft, but i'm not the kind of person that goes around dumping the clutch all the time.
Old Mar 31, 2006 | 10:04 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Power has nothing to do with halfshafts snapping. I snapped a stock halfshaft @ 256whp on slicks. I replaced it with another stocker and since then have added 200whp to my car and haven't broken another one. Halfshafts snap because of SHOCK. If you dump the clutch on ANY Z with heated up sticky tires, you'll have a very good chance of snapping a halfshaft.
That's being said, you'll pretty much never break one with street tires.
Old Mar 31, 2006 | 10:19 AM
barthelb's Avatar
barthelb
Master
Exactly, also like Bri mentioned its the halfshaft and not the driveshaft,try not to confuse the two because the way the driveshaft looks I don't know what kind of power will break that. Ive done numerous 4500rpm-5k launches and luckily im still in one piece.
Old Mar 31, 2006 | 10:24 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Thanks guys. Sorry about the translation, here we call the drivashaft what you call the halfshaft, and the propshaft what you call the driveshaft. Thanks any guys!!
Old Mar 31, 2006 | 10:42 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Its actually the "axle". The drive shaft is the long shaft the connects from your transmission to your differential carrier.
That said, with enough time, even stock axles will gradually fatigue and break. Shock, but also trq on the axle creates a gradually twist/release to the shaft, and with enough fatigue, they will break with time.
At 400whp, I would run the stockers until you break them...them upgrade to Level 2 DSS axles:
Old Mar 31, 2006 | 11:30 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
That´s what i had in mind. At least that way i´ll have ans excuse to get them!
Old Mar 31, 2006 | 01:27 PM
schweatty's Avatar
schweatty
exactly... i always thought half-shafts were an all-wheel-drive thing.
Old Mar 31, 2006 | 03:36 PM
barthelb's Avatar
barthelb
Master
So they are axles then, dammit. Oh well at least we know what eachother is saying even tho we all have different terminology. hahah
_koubie_
Sep 20, 2015 06:34 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
