Having problems w/turbonetics kit
Old Apr 9, 2006 | 07:55 PM
sam-z's Avatar
sam-z
Default Having problems w/turbonetics kit
Having over boost problems bad.Changed to a 5 and 7 pound w/g spring.Checked all boost lines and even replaced to be safe.W/G line hooked up wright bottom port of w/g to pressure source on turbo.And even installed overboost pipe.Put springs in after i got overboost pipe.No matter what hitting up to 11 pounds.Checked my manifold for leakage (none)kinetix manifold.
Old Apr 9, 2006 | 07:59 PM
blackend's Avatar
blackend
add your name in this list
https://my350z.com/forum/forced-induction/163095-tnetics-overboost-w-aftermarket-exhaust-list.html
Old Apr 9, 2006 | 08:04 PM
sam-z's Avatar
sam-z
I've installed that pipe.
Old Apr 10, 2006 | 06:05 AM
MIAPLAYA's Avatar
MIAPLAYA
Hmm Are you sure the vacuum source from the turbo is not blocked. Can you remove the line and push air through it? Also what does your boost gauge read at idle?
Old Apr 10, 2006 | 04:10 PM
sam-z's Avatar
sam-z
20 vacum
Old Apr 11, 2006 | 07:14 AM
sam-z's Avatar
sam-z
Miaplaya give me a call i pm you.
Old Apr 11, 2006 | 07:56 AM
MIAPLAYA's Avatar
MIAPLAYA
Sam,
I'll give you a call this afternoon I didn't get your PM until late last night like close to 1AM your time.
Uriyo_
Sep 8, 2021 08:46 AM
