Just got my car back and.....
Old Apr 14, 2006 | 05:12 PM
GMADD's Avatar
GMADD
Default Just got my car back and.....
Today, I got my car back from my shop.
added JWT S2 cams, CJM fuel return, 550cc injectors, AAM oil pan spacer and the Stillen brake master cylinder stiffener.
The car pulls like crazy after 4.5k !!!
Idle is a little shaky but no problems.
But on my way home tonight, the SES light goes on
Never had it on before.
What can it be ?
Thanks !
Tasso-
Old Apr 14, 2006 | 05:15 PM
zz350zz's Avatar
zz350zz
I don't know what it could be....but damn I'm jealous and wish my SES light went on because I had all that sweet stuff on my car
Old Apr 14, 2006 | 05:16 PM
booger's Avatar
booger
Most likely a p300 code . A mis fire code most get with return fuel system and bigger injectors . No biggy , but have it checked to make sure
Old Apr 14, 2006 | 05:18 PM
dens_310's Avatar
dens_310
nice... have fun bro
Old Apr 14, 2006 | 05:24 PM
GMADD's Avatar
GMADD
So IF it's a mis fire, I'm ok right ?
but I'll go back on tuesday to make sure.
It's just that even with all my mods I never got an SES light.
I guess I just got a little scared
Thanks !
Old Apr 14, 2006 | 05:25 PM
booger's Avatar
booger
Its a mis fire at start up
Old Apr 14, 2006 | 07:38 PM
Madelinot's Avatar
Madelinot
Which shop does your work? In Montréal?
Thanks!
Old Apr 14, 2006 | 08:20 PM
sentry65's Avatar
sentry65
the burninator
cams always seem to do misfire codes, and it makes sense since the car is firing differently than the stock ECU was designed to understand
I'd consider it normal
Old Apr 14, 2006 | 10:47 PM
calimarc's Avatar
calimarc
My car throws the code ( random misfire code ) about every three months. It was doing it more often but it seems the ECU is learning the changes it's seeing with my after market cams. Go to Auto Zone and they will let you borrow a code reader. After reading the code you can clear it. Unplugging the negative battery cable for 15 seconds will reset the ECU also...but I have found that clearing it with the code reader seems to keep it ( SES ) away longer.
The problem I am having is after turning my VDC off it still kicks in when I go WOT or even close to it. My brake light and slip light will illuminate and after awhile the brake light goes off but not the slip light. I guess there is no way to completely disengage the VDC without messing with the ABS system? Anyone one else want to chime it with experience?
Old Apr 14, 2006 | 11:58 PM
GMADD's Avatar
GMADD
Thanks!
It's CAMO TUNING in Lachine, Montreal.
Old Apr 15, 2006 | 06:26 AM
onyx350z's Avatar
onyx350z
I get the same problem with the SES light... it has come on twice since I had the car done. The first time I just disconnected the negative battery terminal and no problems and about 2 months later it came on again so, I was going to get it checked this time and it shut itself off after a couple of days. The car seems to be running great so no worries, I guess.
Old Apr 15, 2006 | 09:12 AM
turismo's Avatar
turismo
Mine use to do the same thing. You can disconnect the vdc by unplugging it under the center console.
Old Apr 15, 2006 | 10:24 AM
calimarc's Avatar
calimarc
Does that mess with the ABS system? I thought I read that....don't want to go that route if that is the case. thanx
Old Apr 15, 2006 | 12:46 PM
GMADD's Avatar
GMADD
If I unplug the negative battery cable to reset my ECU,
Wouldn't that effect my tune from TS ?
Old Apr 15, 2006 | 01:57 PM
theking's Avatar
theking
No it won't. Some of the long term fuel trims the computer has started running will change but it won't effect it very much.
Old Apr 15, 2006 | 01:59 PM
GMADD's Avatar
GMADD
Cool
Thanks !
Old Apr 16, 2006 | 07:34 AM
Peking's Avatar
Peking
You doing all that with a flash from someone far from you, brave man.
I guess I could understand more if you drove to someone and in house they flashed your ECU then a mail in.
Once again brave, all that money spent seems another form of EMS would be the better bet.
But to each their own.
Good luck, and hopefully it is just the common code.
Old Apr 16, 2006 | 09:42 AM
GMADD's Avatar
GMADD
I know I know.
I'll be upgrading to the EU soon and have it tuned.
I'll have about a month off in may-june, so I'll come down to the States for the tune (not sure where yet).
Tasso-
Old Apr 19, 2006 | 12:51 PM
GMADD's Avatar
GMADD
Ok...
So it's a P0183 code
Fuel temperature sensor circuit high input.
We reset it.
What caused this ?
Old Apr 19, 2006 | 02:47 PM
theking's Avatar
theking
It's happened to me once before. I reset it and it never came back.
Ok...
We reset it.
What caused this ?
