t-netics mod question
Old May 4, 2006 | 05:01 PM
faster than u's Avatar
faster than u
Default t-netics mod question
you guys are going to tell me to search but i already did and cant find what im really looking for, but what mods can i do if any with the stock reflash with the t-netics without making it run like **** or somthing. , my plans so far is just the jwt clutch and flywheel, and i want to run open downpipe also, maybe have a custom pipe made so i dont roast the bottom of my car, all suggestions will help
thanks
Old May 4, 2006 | 05:34 PM
jlimquest's Avatar
jlimquest
Motordyne 5/16 plenum spacer & jet hot 2000 coating for the OEM headers.
Old May 4, 2006 | 07:21 PM
faster than u
how much power did you make with that on your setup thanks
Old May 4, 2006 | 09:53 PM
jlimquest's Avatar
jlimquest
356 whp on a Mustang dyno w/ CAT 5AT. Here's the post:
https://my350z.com/forum/forced-induction/174014-turbonetics-at-w-cat-by-danzio-worth-the-wait.html
Old May 4, 2006 | 10:00 PM
MIAPLAYA's Avatar
MIAPLAYA
I run an Apexi WS2 exhaust, Motordyne 5/16 spacer personally....
Old May 5, 2006 | 05:54 AM
blackend's Avatar
blackend
from my side 377whp and iam having AAM SPACER AND CUSTOM EXHAUT
Old May 5, 2006 | 06:32 AM
faster than u
and the reflash will still run well with these mods, i want to make at least 410 whp like turran and some others,is this possible
Old May 5, 2006 | 06:36 AM
MIAPLAYA's Avatar
MIAPLAYA
Taurran is running a boost controller and 9 PSI of boost. Tread lightly when turning up the boost on the reflash. ALthough its designed to handle 9.5 PSI you are nearing the limit of the injectors. If you want to make a solid 400 RWHP with plenty of safety and headroom consider Turbonetics Stage 1.5 kit..
Old May 5, 2006 | 06:39 AM
faster than u
when does that kit come out
Old May 5, 2006 | 06:40 AM
faster than u
i hear alot about it from reading threads but havent seen it, what do you mean Tread lightly
Old May 5, 2006 | 06:45 AM
MIAPLAYA's Avatar
MIAPLAYA
Tread lightly meaning don't go upping the boost unless you are testing it on a dyno to ensure your AFR is good. Stage 1.5 should be out in the next month or so. It adds the Unichip Q with flux display, closed loop boost control, fuel return system, 630 cc injectors, 6 channel datalogging via Bluetooth, 5 map switch, etc..
Old May 5, 2006 | 06:57 AM
faster than u
its going to be alot though huh....
Old May 5, 2006 | 07:02 AM
MIAPLAYA's Avatar
MIAPLAYA
Shouldn't be too much more then the Stage 1 but I don't have a final price yet...
Old May 5, 2006 | 07:28 AM
taurran's Avatar
taurran
I can run 10psi on 100 octane no problem.
Old May 6, 2006 | 10:14 AM
meme's Avatar
meme
i got 381hp/367 tq.
motordyn plenum spacer,jwt oil pan spacer,full 3in exhaust(off ebay/ with a big muffler). i'm now using buddy club titanium exhaust, 1 step colder plugs.
Old May 6, 2006 | 12:32 PM
Gumpdriver's Avatar
Gumpdriver
Mine made 390hp on a stock exhaust.
Old May 8, 2006 | 05:08 PM
solidsnake's Avatar
solidsnake
damn!! stock exhaust seems to work good with this kit. im gonna put mine back on. or dyno with my single and compare to my stock #'s.
Old May 9, 2006 | 09:55 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I made 392whp 391ft/lbs on the stock flash and Crawford plenum, JIC 80mm isngle exhuast and crank pulley. Thing is my car boosted 9-10psi, and I ran low 12's A/F on the street causing my car to detonate up top, so I couldnt really drive it. Generally the more you mod away from stock the more chances you have of needing a piggyback.
Old May 9, 2006 | 04:48 PM
AReddy14's Avatar
AReddy14
whats an optimum afr on the street? i'm running 12's as well.
Old May 9, 2006 | 05:59 PM
solidsnake's Avatar
solidsnake
i run 10.0 at WOT. normal driving is about 15.1 should i get a piggyback? is emanage ultimate any good?
