Overheating, weird color coolant, coolant all over engine.. pictures
Old Jul 11, 2006 | 08:31 PM
rookie's Avatar
rookie
Originally Posted by MRC Motorsports
looks like a boil over, dont think anything is to messed up..Look like some rust from the radiator floating on the surface..
So the brown stuff is rust? Sorry if this is a dumb question are the greddy turbos are oil cooled?
Old Jul 11, 2006 | 08:40 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
the brass looking pipes on your cooling system are prone to rust for some reason. i have taken off a few of them that are corrosive and rusting looking.
i am guessing that he ran low on coolant and then boiled over his car....
Old Jul 11, 2006 | 08:46 PM
rookie's Avatar
rookie
Sorry for another dumb question. The fluid line is normally on the bottom of the overflow unless it's the Greddy kit, would that have anything to do with the "explosion" type of overflow?
Alberto's Avatar
Alberto
Cranky FI Owner
Sorry to hear this. Is the car tuned at 5.5 psi or is it an out of the box Greddy tune? Sucks so many cars are experiences issues like this now...
Old Jul 11, 2006 | 09:08 PM
Audible Mayhem
My350z
i heard that it was out of the box Greddy, with a really conservative tune, i think it made low 300s with 5 psi...
Old Jul 11, 2006 | 10:11 PM
nissansource's Avatar
nissansource
wow that sucks could be acouple of things do a leak down on the motor and or look for little bubbles under the oil cap. for me this hasnt happend to me on my VQ but one of my high powered SR20s ive had cooling issues after some hard 542hp runs on it =)
Old Jul 12, 2006 | 03:49 PM
doug's Avatar
doug
Back with pictures of the oil..
also i filled her up with coolant, then took it for a 10 min ride through town.. then a 5 min ride on the highway... Temp needle never went higher than normal .. which i think is about 1/3 or so... Jules i am going to drive it for the next two days and if everything is ok.. i will head down to NJ on Sat
but here are the pics anyway
Old Jul 12, 2006 | 04:06 PM
Julian@MRC's Avatar
Julian@MRC
Yeah oil looks ok...Most likely, air in the system or Thermostat stuck..
Old Jul 12, 2006 | 04:18 PM
doug's Avatar
doug
thanks for all your help man.. and calming me down.. i was freaking out for a sec.. hopefully i see you Sat.. what time is good?
Old Jul 12, 2006 | 05:38 PM
k3silk's Avatar
k3silk
I will pray to the car gods for you that everything goes ok. Cooling problems are a pain cause it can be so many thing my last built turbo gsr had a cooling problem it was a pain in the @SS never really got it fixed but oh well. Hope everything go's ok.
Old Jul 12, 2006 | 06:19 PM
Weqster's Avatar
Weqster
U wont mix coolant with oil if u are blowing combustion into the water jackets. we have open deck blocks with MLS headgaskets and large headgasket breaches allowing coolant to flow into the oil are quite rare.
A good test for headgasket breach due to combustion pressure of FI - these will NOT appear on TK tests - is to simply boost a couple of times, pull over and check the overflow bottle. Pull the lid off and smell the coolant immediatly. Also look at the texture of the coolant, if it is like a fizzy drink and has small floating greyish/black particals in it, its a headgasket issue.
I still maintain that is it a heagasket breach. I say this for 3 reasons.
1) The coolant looks suspisiously murky with particals in it. You radiator will NOT contaminate with rust like that unless u are running straight water, then u have much bigger problems.
2) The overflow tank empty. This means that pressure has purged the coolant out. If it was a normal overheat, it would seep out and not splatter like it has (coolant everywhere on the airfilter/piping etc) and still be full.
3) If it was an thermostat/bubbles issue, the car would still overheat. The OP said the car was fine for the short drive he took it on.
Old Jul 13, 2006 | 09:08 AM
vq35carel's Avatar
vq35carel
FYI
I had the same issue.... Air bubbles or the thermostat so I replaced the thermostat with a nismo and fill the resivor as well as the radiator and as you pump the line the lines the bubbles will surface out the top of the radiator with the cap off.This worked for me.
Old Jul 13, 2006 | 11:45 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
How long have you had this kit installed, and has it been tuned? Are you running the original emanage blue?
Old Jul 14, 2006 | 01:48 AM
doug's Avatar
doug
1 month / 2600 miles, yes tuned.... yes emanage blue
Old Jul 14, 2006 | 05:38 AM
Sharif@Forged
Forged Performance
Timing harness installed Doug?
Old Jul 14, 2006 | 06:49 AM
doug's Avatar
doug
i am not sure.. only Jules could tell you .. he did the install and tune
Old Jul 14, 2006 | 07:26 AM
gringott's Avatar
gringott
One thing I noticed about the Greddy kit is that the "overflow tank" fills from the top. The cooling system is designed to have an expansion tank that has the tube from the radiator neck going to the bottom of the tank, so that when the system cools, it can draw fluid back in. Don't know if this contributes to your problem.
Old Jul 14, 2006 | 07:40 AM
  #38
Sharif@Forged
Forged Performance
Jules as in Julian??
Without timing control, too much timing can cause the overflow, even at stock boost levels.
Old Jul 14, 2006 | 08:44 AM
  #39
doug's Avatar
doug
yeah Julian at MRC
Old Jul 14, 2006 | 09:35 AM
  #40
eat rice z33's Avatar
eat rice z33
hey doug the oil does indeed look normal(not to far from your next change either) but congrats! i would just get some water wetter, and perhaps a thermostate. if you got extra cash and track the car id invest in a oil cooler and larger radiator! Best of luck bro
