Saga Gauges
Old Jul 24, 2006 | 08:33 PM
synth19's Avatar
synth19
Default Saga Gauges
Does anyone have any real info on the quality of these gauges? I know they are made in Japan and I've read a few good reviews on evolutionm....Anyone purchase them? I'm pretty sure only available in metric....
Functions:
* High Precision, full angle step motor used by the core.
* Full series electronic High-Precision Sensor (+/- 1% Error RATE)
* Max panel (68mm Face), and 60mm cylinder shell design
* Abnormality self-detection warnings function.
* ON/OFF self-sweeping inspection function. On, a slow then fast arm
secondary sweep. Off, a fast then slow arm secondary sweep
* Alert value setting, arm flickering, buzzer sounding function
* Nighttime light source brightness automatic attenuation function.
* Black, heat resistant, anti-UV optical Mask design.
* Self-illumination, high contrast, optical panel lighting design. Use
high-illumination, longer life LED light source.
* Light weight, high heat dissipation, full aluminum alloy precious metal
shell.
* Aluminum alloy seat and dashboard sunscreen (Visor)
* External connection large size warning indicator (optional)
* External control box not required Peak value record play back functions.
50-sec traffic record function
* Traffic record play, pause, rewind function
Old Jul 25, 2006 | 05:16 AM
synth19's Avatar
synth19
BUMP! I heard these are also available in american readings... This seems like a viable option to the Defi... Japan made, warrantied, and STAND ALONE!
Here are some more pics:
http://forums.evolutionm.net/showthr...5&page=1&pp=15
Old Jul 25, 2006 | 07:13 AM
gringott's Avatar
gringott
Nice looking guages. Does a site sponsor carry these?
Old Jul 25, 2006 | 07:24 AM
synth19's Avatar
synth19
auto rnd (a site sponsor) carries them, I pointed him to this thread... hopefully he can chime in....
Old Jul 25, 2006 | 08:46 AM
priscilla ls1's Avatar
priscilla ls1
They look ok but I like the Defi BF's. Why dont you want thoughs again?
Old Jul 25, 2006 | 09:19 AM
Oleg's Avatar
Oleg
These do look fine in the dark in terms of blending is with the car's stock gauges, but not when it's light (white vs amber). The red arrow is a definite plus. Also, I do believe that defi's has a blushed aluminum bezel, so they would match the Z's interior even better.
I guess if these are not as expensive it would be a great option.
Old Jul 25, 2006 | 10:03 AM
synth19's Avatar
synth19
Cheaper then the BF series and they don't require a control unit (which you have to dish out another $100 for). Yes, BF's are great...but many ppl (such as myself) do not need all the bells and whistles in comes with.....
Basically, this is a great option for those who have been searching for the Defi D Series.... I know the replacement for the D Series should be out in September, but Defi is screwing us again...they will only be available with a blue LED backing.
Old Jul 25, 2006 | 10:24 AM
synth19's Avatar
synth19
The Saga Gauges come in White or Amber Face! Let’s break it down, this is what I was going to go with: Boost, Oil Temp, Oil Pressure (will replace stock gauges with these).
Saga 2.0 (from 500whp.com)
Boost…………$175
Temp………….$95
Oil Pressure….. $185
Control Unit……N/A
Shipping:………FREE
TOTAL……..$455 SHIPPED
Now let’s compare with Defi’s BF Series (egauges.com)
Boost…………$230.40
Temp………….$201.60
Oil Pressure….. $269.10
Control Unit……$97.75
Shipping………..FREE
TOTAL……..$798.85
DIFFERENCE of $343.85 that can go into a wideband.
Old Jul 25, 2006 | 10:25 AM
gringott's Avatar
gringott
Nice breakdown.
Old Jul 25, 2006 | 10:32 AM
John@Victory's Avatar
John@Victory
guess they will good with my led dash then!
Old Jul 25, 2006 | 02:33 PM
synth19's Avatar
synth19
Okay guys, I just placed an order for the AMBER lighting and AMBER face gauges... I have confirmed, these are available in F/PSI! w00t!!!
Old Jul 25, 2006 | 03:06 PM
GMZ's Avatar
GMZ
Post pics when you get it in!
Old Aug 3, 2006 | 06:38 PM
synth19's Avatar
synth19
gauges came in today! Can't wait to get them installed!
Old Aug 3, 2006 | 07:35 PM
gringott's Avatar
gringott
Very curious on this one, pics are appreciated.
Old Aug 3, 2006 | 07:49 PM
synth19's Avatar
synth19
^ hopefully by the end of next week....
Old Aug 3, 2006 | 07:58 PM
synth19's Avatar
synth19
here's a pic on an evo with the amber lighting:
I'll be putting mine in the stock 3 podder...
Old Aug 3, 2006 | 08:03 PM
synth19's Avatar
synth19
NOTE: THESE COME IN PSI/F! I only found pics of the metric versions....
different color anyone?
Old Aug 3, 2006 | 08:04 PM
synth19's Avatar
synth19
btw, got these from 500whp.com, they have the 2.0 and 5.0 versions... I got the 2.0 ones..
Old Aug 3, 2006 | 08:41 PM
MIAPLAYA's Avatar
MIAPLAYA
Are these full electronic? Do they include the MAP sensor, temp sensors, etc?
Old Aug 3, 2006 | 11:00 PM
draxxus07's Avatar
draxxus07
let me know how these work out for you, im in the market for a set of gauges
