Quick fuel question
If I disconnect my vaccum line to my fuel pressure regulator am I correct in that the pressure should rise ~10psi? If it doesn't rise then the regulator is bad? This is done with the car running
Ok i disconnected the line. it shot up 3-4psi and then went right back down there where it was at when the line was conneted. Is that what it's supposed to do or should it stay at the higher psi?
hmmmmm starting to look that way...is there a way I could test the fuel pump? Like with a meter? Also if the pump was failing would that also be the reason I cant adjust the pressure at the regulator?
