Stalling???
Old Sep 17, 2006 | 06:21 PM
brooke's Avatar
brooke
Default Stalling???
Well after 20k miles on my aps tt setup I'm now having stalling issues. From a dead stop and reving the motor it will not do it but under load while driving and coming to a stop it dies or almost dies. So far I have replaced the spark plugs, installed new belts since they were very worn with cracks, cleaned the MAF with cfr eletrical spray, reset the ecu,checked the BOV, checked for a vacuum leaks and have yet to fix the problem.. My only other guess would be a bad 02 sensor or maybe even a bad MAF..
Thanks,
brooke
Old Sep 17, 2006 | 09:59 PM
brooke's Avatar
brooke
anyone??
Old Sep 17, 2006 | 10:54 PM
G352NV's Avatar
G352NV
Get a tune or raise the idle.
Old Sep 18, 2006 | 12:47 PM
brooke's Avatar
brooke
been tuned by sgp...
Old Sep 18, 2006 | 12:56 PM
G352NV's Avatar
G352NV
How long ago?
Old Sep 18, 2006 | 01:03 PM
brooke's Avatar
brooke
4 months... You think there could be mapping problems with the uni-chip??
Old Sep 18, 2006 | 02:35 PM
G352NV's Avatar
G352NV
Well I do know if the weather has changed in that time it will throw the car off. If this isnt the problem and you car is a pre 04 then just raise the idle at the dealer.
Old Sep 18, 2006 | 02:42 PM
Ruth's Avatar
Ruth
Air flow meter,take it to the shop.Put it on the scope,for codes.
Old Sep 18, 2006 | 08:15 PM
JimRHIT's Avatar
JimRHIT
Does the car hesitate the start right away after the stall? But if you wait ~5-10 seconds it'll fire back up and act like it never happened?
My thoughts: CAS + TPS
Are you throwing a code?
Old Sep 18, 2006 | 08:50 PM
G352NV's Avatar
G352NV
Do a search on this. Lots of APS cars have gone through this.
Old Sep 19, 2006 | 09:14 AM
brooke's Avatar
brooke
I've done searches already. After stalling the car will start right away and run fine. There were 2 check engine lights but I cleared them before thinking they would not come back in which they have not but the car is still stalling.. Maybe a new MAF is in order..
brooke
sherm
Apr 11, 2020 05:21 PM
pslamp32
Feb 8, 2017 09:07 AM
05UltraYellow
Sep 24, 2015 05:41 AM
Darkspy
Sep 7, 2015 09:09 PM
silverstoned
Sep 3, 2003 10:15 AM
