HELP! vortech S/C problems...
Old Oct 17, 2006 | 07:09 AM
dimebagdolf's Avatar
dimebagdolf
Originally Posted by sentry65
switching the SC pulley will really really help with the boost
on my car at 4000 rpms, I think I'm around 4-4.5 lbs of boost - I'd have to double check though
Agreed.
My car starts to pull pretty hard right around that range.
I never had my car w/out all the other mods, so I don't know what kind of power and torque I would have had w/ out all the supporting mods.
Headers are a must my friend. The stock manifolds are pretty bad for a S/C.
Old Oct 17, 2006 | 08:04 AM
sentry65's Avatar
sentry65
the burninator
i checked my boost graph on my dyno from june, I actually make 5 lbs at 4000 rpms - at least in 90 degree conditions with a hot engine
Old Oct 17, 2006 | 10:17 AM
SungNamZ's Avatar
SungNamZ
You might also want to check the + and - connections on the AUX Fuel Pump. If they are reversed, which is easy to do, the pump will not kick in at approximately 3500 - 4000 rmp. Performs like NA. Really shows up on a dyno or while doing a fuel pressure test.
Old Oct 17, 2006 | 01:24 PM
FrickU's Avatar
FrickU
Good luck resolving the problem.
Old Oct 17, 2006 | 03:53 PM
xav_350z's Avatar
xav_350z
i'll take a look at it
actually my z is still parked ( shop) they can't find a new belt...
and we're waiting for the pulley (3.12), and motordyne spacer to tune the box.
@FirckU : 10x man!
Old Oct 18, 2006 | 08:13 AM
xav_350z's Avatar
xav_350z
i took some pics b4 taking my z to the garage last day..
enjoy
any input ?
Old Oct 18, 2006 | 08:16 AM
Barzten1's Avatar
Barzten1
Take a pic of the pulleys that hold the Vortech ribbed belt. That belt is way chewed up. I want to see if your pulley is in the right order.
Edit: I see it in that last pic. Do you have one thats not so close
Old Oct 18, 2006 | 01:50 PM
booger's Avatar
booger
Your belt wasnt put on right . Or the main bracket wasnt installed right
Old Oct 18, 2006 | 04:17 PM
xav_350z's Avatar
xav_350z
well that's all the pics i have for now...
They called me today, they installed a new belt and alligned the pulley.
btw, what about fuel consumption? 27 L / 100 km..
Old Oct 19, 2006 | 09:30 PM
AmyCroft's Avatar
AmyCroft
Smile Use a Straight Edge Metal Meter Guage - Appox 2 Dollars
Go to Walmart (Just Kidding) and buy a yard stick/ Meter rod - when you place this rod next to the line of the Vortech Pulley's you can see the line is not straight....
The axis of the supercharger is not perpendicular with the drive pulleys..
Have a Local machinist correct the factory problem. Then report your findings back to this Forum...
There have been two ways to fix the vortech drive versa sc mis-alignment problem posted here. Have fun with your search...
Do you have a few Lasers to Confirm? You will find the two axis (drive vs SC axis) will cross at 20 meters out. Is that enough to confirm a bend of the Aluminum mounting bracket deformation or what? No wonder it eats belts.
Cheers -
Old Oct 19, 2006 | 09:40 PM
AmyCroft's Avatar
AmyCroft
Smile Steel Bracket - Might be easiest
Cheers -
A Steel Bracket - Might be easiest - Duplicate Aluminum Bracket with a laser cut steel backet. And a shim or two..
Old Oct 20, 2006 | 04:43 AM
booger's Avatar
booger
Cheers -
There have been wayyyyyyyyyy to many guys with wayyyyyy to many miles driven on this SC kit . To say what your saying . And if the bracket is flexing it isnt going to tear up his belt that fast.
several guys , or shops have forgot to add shims to a pulley or the bracket , or on the wrong side of either . That would more than likely be your problem
Old Oct 21, 2006 | 07:00 AM
SungNamZ's Avatar
SungNamZ
+1. One or more of your pullies were not install properly.
A lot of "new" threads/posts have appeared while I traveled to Costa Rica and figured out WIFI down here
Old Oct 21, 2006 | 08:16 AM
xav_350z's Avatar
xav_350z
got my z back,they adjust the BOV and pulleys and installed a new belt....
i can keep up now with a stillen stage 4 z ....
i still need a good tune
Old Oct 21, 2006 | 04:26 PM
electricmarquis's Avatar
electricmarquis
so what was the issue? BOV and misaligned pully?
Old Oct 22, 2006 | 03:10 AM
xav_350z's Avatar
xav_350z
exactly...
Old Oct 22, 2006 | 07:13 AM
xav_350z's Avatar
xav_350z
guys the gauge (stock gauge) which indicates fuel consumption and stuff is not working properly...the speedometer indicates a certain speed despite I'm stopped
u think its caused by the ss box is badly wired?
Old Oct 22, 2006 | 08:28 AM
  #38
electricmarquis
Alot of people I talk to about wiring ecu's buy a extended harness so if they run into problems they just plug old harness in to see if its a wiring problem.
Old Oct 22, 2006 | 10:28 PM
  #39
Triji's Avatar
Triji
Hey Xav... I am glad you got alot of your stuff worked out bro...
From your pictures they jumped a rib when they put your belt on and it was overlaping on the bracket side. Your freying on the belt was from the belt rubbing on a couple of the screws... I grinded down a couple of those a bit for more clearance.
GET A TUNE
Old Oct 23, 2006 | 01:47 AM
  #40
xav_350z's Avatar
xav_350z
GET A TUNE
hey Triji!
that's exactly what they did, the belt was rubbing on a screw...its fixed now
as for the tune, well i guess we'll buy the R4 software
