e-manage problems
Old Oct 23, 2006 | 01:02 PM
bbs350z's Avatar
bbs350z
Default e-manage problems
ive been reading and i hear that theres lots of problems w/ the pre-tuned e-manage that comes in the twin turbo kit. i plan on buying the kit (upgrading the fuel system etc.) but i hear that its prone to blowing up your motor. can u guys help me out please?
Old Oct 23, 2006 | 01:51 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Simple, get a UTEC, or FCON Vpro
Old Oct 23, 2006 | 07:14 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The out of the box Greddy kit is a timebomb. It is a good hardware kit, and really shines with the right fuel and EMS. As mentioned, the UTEC or FCON is your best bet. Coupled with a return fuel system, blow off valve, and good tuning....400whp can be had easily with the stock block.
Old Oct 23, 2006 | 07:26 PM
bbs350z's Avatar
bbs350z
is it the e-manage in general, it needs a retune, or simply sucks all in all??
Old Oct 23, 2006 | 07:31 PM
Sharif@Forged
Forged Performance
The eManage blue is very primitive. If you get the timing harness, diodes, and have it retuned, it would probably reasonable safe at mild boost. But its a compromise, and there are much better and safer way to tune the cars.
Old Oct 23, 2006 | 08:10 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Believe me, I'm pretty much wishing I had gone for the UTEC right off the bat instead of trying to save a few hundred $ by going with the Emanage Ultimate.
For example I can't really guess why advancing timing with the EU resulted in loss of power, but advancing timing with cipher (via the stock ECU) resulted in nice gains. I think the stock ECU did not like the EU messing with timing and must have overcompensated by pulling it back. Not sure though.
It just seems that the emanage ultimate has very poor timing control. And the emanage blue has no business anywhere near a turbo kit.
Old Oct 23, 2006 | 11:34 PM
TENGAI's Avatar
TENGAI
Simply put - if you plan on going with the GReddy (which is an awesome base kit), then look into a better engine management. The UTEC is awesome for the $, and there's tons of support for it. If you want the cream of the crop, then go with the F-Con....
Old Oct 23, 2006 | 11:37 PM
Xx SiFaKa's Avatar
Xx SiFaKa
What Fuel return system do you suggest with the Greddy kit?
Old Oct 24, 2006 | 12:20 PM
supra crazy's Avatar
supra crazy
Do you think the same if useing Emanage Ultimate?
also would you or anyone have a base fuel map? for EU?
Old Oct 24, 2006 | 01:05 PM
bbs350z's Avatar
bbs350z
when i get it, i planned on swappin out injectors because the 440's r 2 small for the power i wanna make, and im probably pickin up a utec and the aam fuel rail and a walbro 255 pump pretty soon, before i get the kit.
Old Oct 25, 2006 | 10:18 AM
Three5oZee's Avatar
Three5oZee
Talking
ahhhh... well i have the primitive e-manage (blue box) interfacing with the TN reflash on my TN set up. Im at 9.5lbs boost an it runs great.. smooth although its still a bit rich. I am currently just over 400hp at the wheels w/ about equal torque. (pretty close in numbers)
Anyway... im planning on moving over to the HKS F-Con set up. The greddy set up with your car just to start off with is not a bad thing.. its a good building block so that you are running with boost. then form there after you buy your components ie fuel set up.. make sure you get a larger radiator an well then you can move up in programming to see newer numbers.
Thats just my opinion.
Old Oct 25, 2006 | 12:17 PM
002-M-P's Avatar
002-M-P
I had the emanage blue...then got the emanage ultimate because the utec wasn't available yet...now once I decide whether or not I will build the motor in the spring, I will probably upgrade yet again to utec (Fcon is just soo damn expensive)
Old Oct 26, 2006 | 06:30 PM
bbs350z's Avatar
bbs350z
will the e-manage hold up w/ about 430 rwhp? i plan on runnin this from nxt spring thru summer and im upgrading everything (as i built motor, fuel system, etc.) in the winter while its stored.
Old Oct 27, 2006 | 08:33 PM
nukepharmer's Avatar
nukepharmer
Default Emanage blue - get something else
I agree with everyone here who says the base Greddy TT kit is great, but the Emanage blue is junk. I WAS running 350 whp at 5.5 psi until a little backfiring problem caused by the Emanage created a much bigger problem. Lots of money later, I'm getting my intake fixed and I'm replacing the blue with the HKS F-Con IS since I can get all of the guage and OBD info on my double-din screen.
Old Nov 6, 2006 | 12:44 PM
bbs350z's Avatar
bbs350z
but the hks f con is a stand alone unit right? the utec isnt a standalone so i hear.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
