Clutch to with stand TT @ 450WHP
I was wondering the same thing with the twin carbon? Also what kind of heat up procedures are there for these clutches. Do you just drag the clutch while giving it gas (kinda try and slip it a little or what)?
The correct method for heating up an Exedy Carbon Clutch is three, five second “slips” of the clutch within 30 seconds. This process may seem excessive but is necessary when producing such high power levels.
I would buy clutchmasters products from now on. I had a stage 3 with about 530 ft lbs of tq and it started to slip. Now keep in mind this clutch was installed before i built the motor and never really thought to replace it after the build. Now after I dumped the APS STfor an upgraded jwt tt I knew I needed more clutch. Called CM and they gave me a full credit for the stage 3 and sent me a twin disc and I just payed the difference. Also it was the least chatter that ive heard for a light flywheel.
Originally Posted by seeulater
Sweet! Where can you get the twin carbon clutch??
Otherwise, any shop should be able to order you one - SGP, GTM, GRD
Here it is for $1990. Sharif @ Forged will match it.
http://www.importpartspro.com/atstwdicacac.html
JET
JET
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
