Strangest Boost Issue ever.......
Old Nov 8, 2006 | 12:24 PM
QuadCam's Avatar
QuadCam
maybe you somehow melted all the blades off the turbine side of the turbo. I've seen it on RX-7s (but those roataries are like blowtorches!) If that were the case, the turbo would spin. Take the downpipe off and have a look at the turbine.
Old Nov 8, 2006 | 01:21 PM
ht4's Avatar
ht4
That would not explain the rich condition. I would concentrate on troubleshooting post-maf.
Old Nov 8, 2006 | 08:25 PM
g356gear's Avatar
g356gear
Originally Posted by chimmike
until you make a pressure tester and check according to the pics above, nobody is going to be able to help you.
I guarantee you have a leak. Until you have tested with a pressure tester, you cannot absolutely rule this out.
Also, I've had leaks large enough(yes, on the Z) where ZERO boost was made and it wasn't obvious that there was a leak (compressor outlet popped off a few times and did this)
So please. For your own good, make a pressure tester with a PVC cap like that and cap it over the compressor inlet with a coupler and use even a compressor, or even a bike pump, and put some air in there, 20psi or so, maybe 30, to see how it is.
Well.....your guarantee of a boost leak is wrong my friend. System was pressurized tonight with no leaks...held pressure for several minutes with minimal loss.
A new thought that has come to light was the possibility of the turbo being able to spin freely to the touch but not being able to spin with enough rpm to create boost. Maybe a bearing cartridge problem??
Old Nov 8, 2006 | 08:27 PM
g356gear's Avatar
g356gear
Originally Posted by MIAPLAYA
Could be the plenum itself. I had a buddies whos car had a leak at the plenum and didn't exhibit ANY tpyical vacuum leak stuff. Also check the hot side piping. Maybe the feed side has developed a leak. Could be the BOV or wastegate too.
Hey MIA....BLOV was tightened down to max....no effect. Wastegate was removed and a block off plate installed.....still no boost built up with no wastegate in the system at all.
Old Nov 8, 2006 | 08:30 PM
MIAPLAYA's Avatar
MIAPLAYA
Then theres either a massive leak or the turbo is not spinning. Did you try moving the boost gauge signal to the compressor outlet port. That will tell you how much boost is being made at the turbo before any leaks could occur.
Old Nov 8, 2006 | 08:37 PM
g356gear's Avatar
g356gear
As stated earlier MIA....the system has been pressure tested with no loss of pressure. The impeller does spin when you touch it with your finger.
Old Nov 8, 2006 | 08:39 PM
MIAPLAYA's Avatar
MIAPLAYA
Like I said. If the impeller spins freely by hand, you should move the boost gauge signal to the compressor outlet port to see if its builds any pressure at the compressor housing to see if the turbo is spinning and building pressuer under load. Or remove the air filter section and run the car on the dyno to see if its actually moving... If its not then call Steve or Ed at Turbonetics and they will send you a new turbo...
Old Nov 8, 2006 | 08:42 PM
g356gear's Avatar
g356gear
At this point I am leaning toward a bad turbo. With no exhaust leaks leading to the turbo....and no pressure leaks after the turbo...logic would dictate that the impeller is no spinning fast enough to create a level of boost.
Old Nov 8, 2006 | 08:45 PM
MIAPLAYA's Avatar
MIAPLAYA
Its entirely possible. Good way to check is moving the boost signal to the compressor outlet.
Old Nov 9, 2006 | 05:02 AM
QuadCam's Avatar
QuadCam
take a look at the turbine side blades. Something has to be wrong on the turbine side that is not allowin the whel to spin. if the blades are gone or deformed, that'll explain alot!
Old Nov 9, 2006 | 05:04 AM
chimmike's Avatar
chimmike
if it wasn't spinning fast enough you'd have horrible bogging while driving. Also I don't think it would just go bad without the seals going bad/melting and causing oil to be dumped in both sides and smoking like a chimney............I've never heard of a turbo going bad like that without smoking like crazy.
Old Nov 9, 2006 | 06:13 AM
g356gear's Avatar
g356gear
Well it's not bogging.....it just goes real rich past 1500 rpm's. The options for what could be wrong are getting pretty limited. There is zero smoke....car runs clean.
Old Nov 9, 2006 | 06:17 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I knew it wasn't a boost leak...
Old Nov 9, 2006 | 06:24 AM
chimmike's Avatar
chimmike
it's obvious it'll go rich because it's expecting boost and there is none, heh.
when you did the pressure test, did you open the throttle plate any?
Old Nov 9, 2006 | 11:16 AM
LODOSS's Avatar
LODOSS
I can't hear the turbo on my TN kit..
how noticeable is it suppose to be? I have been in my turbo cars. including my latest addition audi a4 which even in that . the little k03 turbo i can hear it spinning.
Old Nov 9, 2006 | 11:52 AM
LODOSS's Avatar
LODOSS
Does the TN turbo make a high pitch sound sssssssssssssss or is it a more deeper mellow fuuuu sound? maybe i have a boost leak.. its either that or idon't know what big turbos sound like... i would assume they all sound the same... like a jet.
Old Nov 9, 2006 | 11:56 AM
MIAPLAYA's Avatar
MIAPLAYA
Its more like a SSSssssssssss
Old Nov 9, 2006 | 12:31 PM
  #38
QuadCam's Avatar
QuadCam
put your windows down and do a driv-by near a wall...you'll hear it.
Old Nov 9, 2006 | 02:16 PM
  #39
g356gear's Avatar
g356gear
Gee....never thought of that
Old Nov 9, 2006 | 02:19 PM
  #40
g356gear's Avatar
g356gear
No...throttle plate closed.....to test the system for a huge boost leak after the turbo.
