Looking for ProchargerPhotos
I did a search for Procharger and seem to be having trouble finding pictures of the pulley setup. Particularely how the belt arrangment is and how the crank pulley is connected to everything. Does it use the 4-rib for the A/C compressor? Any pictures of the front of the engine with a procharger on it would be much appreciated.
Thanks
Thanks
The Procharger uses to gates belt that do not run the A/C. The A/C belt looks exactly stock. The belt, closest to the radiator, goes from the crank under or over the the tensioner to the the location you see. On the other belt, what you see is all there is. It's a real short belt that goes around the 2 pulley's you see.
I can take some up close pictures if you would like. Let me know what I can do to help.
The gates belt is a combo of cog and serpentine is it not?
If it is then I understand what they do. Basically going clockwise from the bottom of the crank pulley:
From bottom of crank pulley around alternator and up and around powersteering then down under tensioner and back up and around SC front pulley then back down to starting point on bottom side of crank pulley.
Is this correct as stated?
I want on Vortechs site and was able to pull up the installation manual for their kit which gave me an idea of how they do it but they use a serp belt for most of their system where ATI uses a cog belt somehow.
Anymor ehelp would b much appreciated.
