TT Z06 made some great numbers.
Old Dec 10, 2006 | 09:12 PM
  #41
RA11325's Avatar
RA11325
I bet if proper timing is pulled to stave off detonation, I bet it will last a while at 6psi.
Old Dec 10, 2006 | 10:29 PM
  #42
priscilla ls1's Avatar
priscilla ls1
Great work what is this car going to be used for drag or the track? love to see a vid.
Old Dec 10, 2006 | 10:46 PM
  #43
thump_rrr's Avatar
thump_rrr
Originally Posted by bacalhau16
Actually it seems as though a Z with boost and a higher redline, the bottom end fails us, so I cant completely agree with that. It sounded good though!
Actually I would take back your first statement on the excessive RPM's entirely. Most of the time, you can upgrade your valvetrain to such an extent that the piston/rod ratio just cant keep up and with stand it.
I am not speaking about any one brand or line of engines in particular. You are correct in stating that upgrading the valvetrain will alleviate upper end failures.
Are you saying that engine failures in the VQ engies are occuring at high rpm's? The VQ35 is a big bore short stroke engine 95.5mm x 81.4mm which is another reason I find it odd that the bottom end failures are being attributed to excessive rpm.
The mustang 4.6L which has a bore and stroke of 90.2mm x 90.0mm is being spun to 7000rpm at 10-12psi of boost on crappy powder metal rods without failure for the most part. In the mustangs the engines that are failing are typically doing it at or below normal redline which is why fuel and timing are most often to blame. The advantage we have with the mustngs is the amount of data we are able to datalog directly from th PCM. I have been searching for the last 2 days to find as much data as possible on engine failures in the VQ35 but I've been coming up empty on specifics.
I doubt that 6 psi on the Z06 engine will be an issue on a conservative tune.
At an increase of 6.8% per pound of boost a 6psi of boost should give the car something in the area of 710fwhp
This is what a broken rod on a mustang looks like
Old Dec 11, 2006 | 02:50 AM
  #44
silver nismo's Avatar
silver nismo
Originally Posted by deezz
What year is the Z06?
Just checked out Horsepower TV and they had a C6 with STS Twin Turbos, w/ the turbos mounted in the rear of the car(kinda cool) making around 540hp, I believe.
Was pretty cool to see how they mounted the turbos and also how much power can be added to the Vettes with about a 10-11thousand dollar upgrade.
We have the same project in here and the car got 552 whp c6 STS turbos but he lost his stick gear on the dyno poor thing couldn't make it.
Old Dec 11, 2006 | 09:24 AM
  #45
Quamen's Avatar
Quamen
While titanium is strong for it's weight it is also more brittle than steel and has other issues that come with it that can cause issues.
For example, if the rod bolts are not properly coated or of the right material you could get galling with could be an issue if you ever take them out.
I also do not believe that the statement of hp/L is necessarily an accurate measurment for stress analysis. I think that you are going to mislead people by saying such. Effeciency in the entire system could make up for that amount of extra HP.
It could easily be turned around to say that maybe the LSx is less effecient than the VQ.
To everyone else look at the above statement as more so debate rather than fact as I have no clue as to efeciency ratings of each engine and would bet that the LS engine is more effecient.
Old Dec 11, 2006 | 10:24 AM
  #46
Chris Macellaro's Avatar
Chris Macellaro
Originally Posted by gt3
Nice work! Congrats on the numbers!
Thank you sir!
I believe the owner will keep this vehicle off the track as I think he likes street driving the car. I will try to get a video of the car up from the dyno here in a few days as I am about to go out of town to the PRI Show.
thanks guys
Chris Macellaro
Old Dec 11, 2006 | 10:25 AM
  #47
sentry65's Avatar
sentry65
the burninator
I have yet to see a LS7 rod, but my guess is that it's not super heavy duty to withstand huge amounts of boost. Titanium is expensive. Surely GM gave the rods just a little more strength than what was needed, but then again, all you need is a few PSI to spin out in the first 3 gears
Old Dec 11, 2006 | 02:26 PM
  #48
MadBoost's Avatar
MadBoost
Very cool project. We've done about 7 of the APS C6 kits around florida now so this guy will have some company rollin' around the streets.
Old Dec 11, 2006 | 02:32 PM
  #49
sentry65's Avatar
sentry65
the burninator
i'd say the regular C6 is more ideal for boost than the Z07. For sure the engine is cheaper at least if it did blow up
Old Dec 11, 2006 | 02:38 PM
  #50
tig488's Avatar
tig488
i dont think the APS kit holds a candle to this one,
Old Dec 11, 2006 | 08:43 PM
  #51
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
This custom kit in question has wastegate dumps...FTL. I don't see any reason to think that the APS kit isn't as good as this custom setup...not to mention cheaper.
Old Dec 11, 2006 | 09:20 PM
  #52
tig488's Avatar
tig488
better parts all around, bigger/better turbos more efficient for this motor, better intercoolers, better components ie tial vs aps, not to mention the aps external setup sucks hind tit. 321 ss equal length headers, vs cast log headers. better craftsmanship, etc, etc. you can hear the pulses in the headers, pure sex. i just remembered that on the c6 kit, aps uses internal wastegates, not the best choice.
wastegate dumps---FTL, hahahaha, have you looked at the aps external setup by chance? coming off the turbine housing at a 90 degree angle, right at the turbine wheel, and put back into the exhaust at a 90 degree angle---FTL! i dont know what APS infactuation with exhaust backpressure is.
why do you say wastegate dumps FTL. its the best option, if youre talking about the sound, uh, believe me, you can barely hear them over the motor. this isnt a honda.
and of course its cheaper, its a one off kit, now that he has jigs, im sure it wouldnt be so much for the next one. he doesnt have 100 duplicates sitting on the shelf.
Old Dec 11, 2006 | 09:28 PM
  #53
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I hate external dumps...simple as that. Loud and annoying.
Old Dec 11, 2006 | 09:33 PM
  #54
tig488's Avatar
tig488
trust me on this car you hardly notice, altho, its only at 6psi, and the motor is way loud already.
the wastegates have the 5.7psi springs, and just sitting in neutral free revving it opens the dumps, pretty impressive making 6psi with zero engine load.
Old Dec 12, 2006 | 05:53 AM
  #55
Drifto's Avatar
Drifto
Originally Posted by BriGuyMax
Loud and annoying.
The owner of the car agrees with you. He has decided he wants them back in the exhaust. I just figured I'd give him some options. Some like it some don't. I don't care for the noise but it almost always makes more power. On my own personal car I have the wastegate open, but with a tiny suppertrapp on it to quiet down all the racket
The APS kit is really nice and is putting out some great numbers for less money, but this guy wanted a custom set up which always costs more, plus I don't think the APS kit would just "bolt up" to a ZO6 due to the large oil cooler up front and the dry sump plumbing. I would have no quandries with using there kit if a customer wanted it.
Old Dec 12, 2006 | 06:52 AM
  #56
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Would the APS manifolds even bolt up to the LS7? I'd assume the heads are different.
Old Dec 12, 2006 | 04:10 PM
  #57
bacalhau16's Avatar
bacalhau16
thump rrr, as far as excessive rpms with boost in a Z is concerned, I would have to tell you to refer to Alberto on that one. There was a discussion on a thread about how after 6k the amount of stress on the bottom end goes up some 45% or something like that. This is why many Z's with a custom tune and a raised redline were blowing up as apposed to those people using their kits with supplied engine management and utilizing the stock redline. For more information with that though, like I said, Alberto mentioned to us in a thread, and thats what Im going with.
Old Dec 12, 2006 | 04:18 PM
  #58
UGOTZ'D's Avatar
UGOTZ'D
Originally Posted by Ozzie@Hppracing
We race them and work on them. They suck with FI from factory except for NOs. Not taking away from the motor they are good. The reason they don't last that long is from factory they are very loose motors. We are building one right now. The motor will be setup up for turbo and it should make about 1000 easy. Our cobra is a 04, and with our twin turbo kit/pts it makes on 24 psi right at 903rwhp stock motor . We work on the cobras as well and that is really one of the best stock motors to come in a stock car.
Btw try and stay away from rear mount turbos. Here in Dallas there are a few people that have had them stolen from there car. It depends make sure and check how easy they are to get. It has not happen to our customers but other shops have told us that.
i agree the 03-04 cobra motor tops my list of factory motors!
my boy will be pulling his out in the spring with 1000+ rwhp
and once he gets bored with the power he'll be able to do a direct-port 200 shot!
Old Dec 12, 2006 | 06:55 PM
  #59
Zilvia's Avatar
Zilvia
thats just to much......i mean wtf can you really do with all that.
but hey who gives flying nut thats gonna fing sick
Old Dec 12, 2006 | 10:01 PM
  #60
bacalhau16's Avatar
bacalhau16
You do realize that this thread is speaking about a twin turbo C6 Z06 right? I know if I had a 1000hp Mustang who I would be looking for! lol!
Also in a time where there are twin turbo GT40's and Vipers, a 900+ hp cars are just not that uncommon!
