Turbo XS Utec problem
Old Jan 23, 2007 | 10:18 AM
KempieZ's Avatar
KempieZ
Exclamation Turbo XS Utec problem
Hi,
My aps tt kit is installed succesfully but we have encountered some problems with the Utec software. I cant insert my injector size and I dont have any "options" to click on like in the manual. The only thing that comes up the screen is: " For future applications only". It isnt on the cd that came with the computer.
Help!
Thx
Old Jan 23, 2007 | 10:24 AM
BlackTuner's Avatar
BlackTuner
The basic injector scaling feature is not in the 2.8 ver. of software any closed loop fuel changes will need to be applied to the 0 percent column and the 10 to 100 columns are injector pulsewidth.
Thanks,
Jermaine@turboxs.com
Old Jan 23, 2007 | 10:44 AM
KempieZ's Avatar
KempieZ
Its the 2.8d version of the Utec. The duty cycle needs to correspond with the size of the injectors.
Old Jan 23, 2007 | 11:10 AM
KempieZ's Avatar
KempieZ
In the parameters of the UTEC There is first line: open loop fuelling
Second line: Injector flow
third line: Stock injector flow.
Line 2 and 3 says for future use. How to solve this? What did go wrong?
Old Jan 23, 2007 | 01:10 PM
al v's Avatar
al v
You can´t use this 2 lines , you only need to make the corrections in the fuel map , if you are using a 550 cc injectors you need a -15 in the 0% column......
Old Jan 23, 2007 | 01:17 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
just leave the two lines both with 380 and 380 in them, you scale the injectors by changing the 0% column on the fuel map.
550s will be somewhere around -15 % on the 0% column
not a utec problem though
Old Jan 23, 2007 | 03:54 PM
KempieZ's Avatar
KempieZ
We are using the stock aps injectors. They are 500cc at 4 bar fuel pressure.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
