Teflon on turbos?
Old Feb 4, 2007 | 09:09 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Question Teflon on turbos?
I talked to someone last week who recommended coating the turbine/compressor wheels (I'm not sure if he meant turbine, compressor, or both) of the turbo with teflon. He said something about the air flowing over the blades of the wheels better.
Has anyone else heard about this, or had this done to their turbos?
Do any of the turbo kits for the Z/G already have this feature on their turbos?
Old Feb 4, 2007 | 09:13 AM
MIAPLAYA's Avatar
MIAPLAYA
I seem to remember someone doing this on the compressor section. I believe it was Apexi and I think they called it AIRCK or something like that. I don't think the teflon would hold up so well on the turbine side of things...
Old Feb 4, 2007 | 12:33 PM
failsafe306's Avatar
failsafe306
One thing is for sure; your eggs won't stick.
Old Feb 4, 2007 | 06:17 PM
JETPILOT's Avatar
JETPILOT
Teflon on compressor blades will not improve air flowing over the blades.
JET
Old Feb 5, 2007 | 09:23 AM
Quamen's Avatar
Quamen
But being able to say that your turbo has non-stick capabilities should be good for at least 20whp. If you get a sticker that says that it could be even more!
Old Feb 5, 2007 | 09:48 AM
002-M-P's Avatar
002-M-P
Most teflon will become gelatinous at about 600-620F, so use on anything but the compressor side of the turbine would be pointless because it would all melt and spin off the turbine blades the first time you drove it. Teflon is great for frictions in liquidous fluids (PTFE hydraulic hose for example), but I don't think that its benefits would be seen nearly as profoundly with air. Sure it might work, but I doubt it would be worth the effort.
Old Feb 5, 2007 | 10:06 AM
JETPILOT's Avatar
JETPILOT
No..... it wouldn't even "might" work. Actually it would likely be detrimental to performance as the boundary layer would likely move even slower. A rough surface on the compressor blades would be better than a smooth one as the turbulence at the surface of the balde would energize the boundary layer.
JET
Old Feb 5, 2007 | 10:22 AM
002-M-P's Avatar
002-M-P
JET
Indeed, I did not consider this. I guess I was more thinking of flow through an actual channel (say the compressor housing itself) rather than across the blades of the compressor wheel.
Old Feb 5, 2007 | 10:35 AM
MIAPLAYA's Avatar
MIAPLAYA
That was my thought too. That the coating would be applied to the housing...
Heres the information on Apexi AIRICK stuff:
Originally Posted by Apexi
he AIRICK system incorporates a patented material in between the compressor housing and the compressor blade. The insertion of this material allows near 0 clearance between the blade and housing improving compressor efficiency by almost 5-6% all across the board. AIRICK also lowers compressor outlet temperatures under high load by 50-68 degrees F. This not only improves overall maximum output, but improves the boost response right before the intercept point of the turbine.
Old Feb 5, 2007 | 11:21 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Thanks for the input guys.
I had never heard about using teflon before, so I was curious. I also had my doubts about how teflon would hold up in high temperatures involved with turbos.
The advice I got was from an old racer (raced 15+ years ago) and I thought it was worth asking about here. He only discussed it in passing, so I don't have any further background info or details about it. But after I talked to him and thought about it, I was intrigued, especially if it was viable to give a slight performance edge over competition with stock turbos.
bcoffee20
Nov 19, 2015 06:39 PM
