Installing a Turbonetics ST kit
Old Mar 13, 2007 | 02:25 PM
  #41
boostintt's Avatar
boostintt
b
Old Mar 13, 2007 | 09:18 PM
  #42
boostintt's Avatar
boostintt
and she lives... just got done installing the emanage blue, she turns on and sound good.... now where do i get the maps??? software??? huh??? yea...
Old Mar 14, 2007 | 10:48 AM
  #43
boostintt's Avatar
boostintt
she might not b the fastest but damn she looks good...
Old Mar 14, 2007 | 10:51 AM
  #44
QuicksilverZ33's Avatar
QuicksilverZ33
Nice!
Old Mar 14, 2007 | 11:02 AM
  #45
vitaminZ's Avatar
vitaminZ
Nice!!! hope for great numbers out of your set up...
Old Mar 14, 2007 | 11:03 AM
  #46
bbs350z's Avatar
bbs350z
wanna c how this turns out
Old Mar 14, 2007 | 11:07 AM
  #47
bbs350z's Avatar
bbs350z
how does this pull compared 2 a greddy tt setup? is it just a massive pull outta nowhere?
Old Mar 14, 2007 | 11:09 AM
  #48
IIQuickSilverII's Avatar
IIQuickSilverII
another think you can do to make her look good is to get 25mm spacers for your rear wheels man
Old Mar 14, 2007 | 12:27 PM
  #49
boostintt's Avatar
boostintt
very nice... very clean...
Old Mar 14, 2007 | 12:28 PM
  #50
boostintt's Avatar
boostintt
i need spacers for my front wheels thats for sho...
Old Mar 14, 2007 | 02:40 PM
  #51
boostintt's Avatar
boostintt
i just installed this tn st with 440cc injectors, ssv, stock exhaust, greddy emanage blue (i know get rid of it and get a utec... im broke so no utec for a while) and tial wastegate with a .5 bar spring.
i have the software for the emanage...
i called greddy and they told me they dont have a map for my application only for the greddy tt kit.
does anyone have a safe streed map i can load onto my emanage... i will be taking it to get it tuned but meanwhile i need some sort of map to drive around... and mayb test out my new toy...
thanks for the help guys.
  #52
diwun67's Avatar
diwun67
Sweet, now go dyno that bish!!
Old Mar 14, 2007 | 02:43 PM
  #53
Blu_Blur's Avatar
Blu_Blur
Originally Posted by ZU L8R
Sell the Emanage blue and get a Utec
...or an E-manage Ultimate.
When I was reading his list, that was the first flag that came to mind- get rid of the Blue.
I use the Greddy EU and it works great!
  #54
azula's Avatar
azula
man its coming along nicely, good luck and get us some numbers!!
Old Mar 14, 2007 | 02:44 PM
  #55
Blu_Blur's Avatar
Blu_Blur
No need to borrow a street map if you are getting it dyno'd unless you meant dynoing for just numbers and not tuning.
Just go easy on it until you get a good EMS system and unlike what someone else posted on here DO NOT drive it like you stole it. One of the most idiotic things you can do to a stock internal FI Z ESPECIALLY without a good EMS.
Old Mar 14, 2007 | 03:22 PM
  #56
boostintt's Avatar
boostintt
thanks... so can i drive the car right now w/out a map... and with out gettin into boost to get it tuned?
Old Mar 14, 2007 | 03:28 PM
  #57
Blu_Blur's Avatar
Blu_Blur
No problem,
You SHOULD be able to drive it and definetly don't put it into boost which starts around 2,900 rpm for the TN kit (atleast mine did). Listen for soudns of crackling or like a plastic or paper bag crumpling coming from your engine. Those are signs of detonation. If you see smoke coming from the engine, check it out but more than likely it will be from the heat wrapping and stuff but since the kit is used, that may not happen (the smoke.)
If it is not too much trouble, I highly advised getting your car towed to the tuning shop. If you can't get it towed, have someone escort you and drive behind you just incase anything happens.
So are you getting dyno tuning done or just dynoing for numbers?
For tuning, for safety sake, make sure that they start-off with a rich map to prevent detonation. As far as I know, this si standard operating procedure. The tuner will then lean it out pull after pull after pull. Make sure you ask about this if you are not sure. I know that my Greddy EU came with a 'start-up' tune which was very rich throughout the rev range and the tuner would pull fuel as he went.
With FI, always err on the side of caution.
Old Mar 14, 2007 | 03:36 PM
  #58
boostintt's Avatar
boostintt
No problem,
You SHOULD be able to drive it and definetly don't put it into boost which starts around 2,900 rpm for the TN kit (atleast mine did). Listen for soudns of crackling or like a plastic or paper bag crumpling coming from your engine. Those are signs of detonation. If you see smoke coming from the engine, check it out but mroe than likely it will be from the heat wrapping and stuff btu since the kti is used, that may not happen (the smoke.)
If it is not too much trouble, I highly advised getting your car towed to the tuning shop. If you can't get it towed, have someone escort you and drive behidn you just incase anything happens.
i might just take it to performance factory here in orlando...
  #59
boostintt's Avatar
boostintt
i thought i could just get a simple street map and upload it into my emanage and go...
Old Mar 14, 2007 | 04:59 PM
  #60
boostintt's Avatar
boostintt
awwwwwwwwww i just wanna boost... please someone help...
