Spark Plugs: Platinum or Iridium for F/I ??
Old May 1, 2007 | 09:55 PM
Triple8Sol's Avatar
Triple8Sol
Definitely not going to go 2 steps colder. No need for that.
Old May 2, 2007 | 06:41 PM
vqturbotec's Avatar
vqturbotec
do you have a stock motor if not what is the compression ratio of your engine
Old May 2, 2007 | 10:44 PM
Triple8Sol's Avatar
Triple8Sol
Stock block
Old May 3, 2007 | 07:32 AM
vqturbotec's Avatar
vqturbotec
i would run 1 step colder plugs (ngk iridium ) and gap them down to .025 and maybe spend a little tune time just to make sure it dosent detionate in the high revs
Old Jun 24, 2008 | 02:58 PM
TurboSam's Avatar
TurboSam
bringing back an old thread if i can.... anyone know WHICH copper plugs to use?
Old Jun 24, 2008 | 05:17 PM
beastie's Avatar
beastie
The only issue I had with iridium is they break easily when re-gaping.
Old Jun 24, 2008 | 06:15 PM
Cannysage's Avatar
Cannysage
i have iridium
Old Jun 24, 2008 | 09:42 PM
Nforce1's Avatar
Nforce1
Im going to be getting new plugs myself this coming week or so...
Old Jun 24, 2008 | 09:52 PM
Spork's Avatar
Spork
IIRC, the platinum puck on the platinum plugs can come off from the increased pressure and cause damage.
Old Jun 24, 2008 | 09:54 PM
Spork's Avatar
Spork
Originally Posted by Triple8Sol
I thought iridiums were too sensitive or fragile to gap?
To gap bigger, they are fragile and you can NOT gap them larger in my experiences.
Closing the gap just takes some pressure on the arm to close the gap up. This does not require pressure on the iridium part.
Old Jun 25, 2008 | 12:06 AM
silver nismo's Avatar
silver nismo
And why is that???
The 1 step and 2 step are the same how ever you can have more advanced timing on the 2 step. any other wise reason why u wouldn't go for something that is colder and might protect your engine more???????
Old Jun 25, 2008 | 12:07 AM
silver nismo
As for the Plat. they r fine iridium r better its as simple as this :-)
Old Jun 25, 2008 | 04:54 AM
TurboSam's Avatar
TurboSam
Old Jun 25, 2008 | 07:34 AM
NETSHARK's Avatar
NETSHARK
Originally Posted by silver nismo
And why is that???
+1 i want to know why please ? BTW we live in the Oven Side of the World don`t ever compare our temperature in the summer to any other part of the world
Old Jun 26, 2008 | 08:16 AM
Jay'Z's Avatar
Jay'Z
What are you guys closing the gap to??
Old Jun 26, 2008 | 09:01 AM
reptile718's Avatar
reptile718
+1 I have been using the same iridium plugs for the past 2 years without any problems and they where never gapped. I was told they are too sensitive and where already pre gapped to the correct specs. Also when should the plugs be replaced?
Old Jun 26, 2008 | 09:59 AM
Jay'Z's Avatar
Jay'Z
Id replace my plugs about every 30k miles.. But if im correct my iridiums came with a .045 gap or something close to that..
Old Jun 26, 2008 | 11:01 AM
  #38
beastie's Avatar
beastie
I had to close the gap when I ran Nitrous and I broke a couple of the arms. I thought the arms were Iridium or at least a weaker material becuase the plat and copper plugs never broke on me.
Old Jun 26, 2008 | 12:41 PM
  #39
QuadCam's Avatar
QuadCam
NGK LFR6A-11
Old Jun 26, 2008 | 01:30 PM
  #40
Jay'Z's Avatar
Jay'Z
What gap is good on the coppers? are those 1 step colder? is .025 safe?
