Gear Dependent Boost?
Old May 20, 2007 | 02:41 AM
JETPILOT's Avatar
JETPILOT
Default Gear Dependent Boost?
Is there a boost controler available that can control boost dependent on gear weather it senses what gear you are in by way of a solenoid and switches to a higher boost setting or is selectable manually.
I will have the UTEC controling my BCS. Can something be done through the UTEC?
Turbo XS has a mechanical quad stage boost controller that uses solenoids to switch between preset boost levels and they says it can be switched electronicly in a number of different ways. Either by electrical switch on the drivers wheel or by gearbox microswitch. How and where could I hook up a gearbox microswitch that would sense a gear change. Any ideas?
The Turbo XS site says about the DTEC Boost Controller Pro (DTEC-BC-PRO) ... "The DTEC-BC-PRO allows everything from simple "one number" boost control that can be set up in minutes to the most advanced closed loop, gear dependant, RPM, and throttle position based programmable boost controller ever conceived'. Does anyone know how to hook this up for gear dependant boost?
If someone can figure out gear dependant boost control High HP Z's will be much faster cars.
JET
Old May 20, 2007 | 04:36 AM
merlin3's Avatar
merlin3
my avcr does gear specific boost levels
Old May 20, 2007 | 08:25 AM
QuadCam's Avatar
QuadCam
Larry,
Use you foot to modulate it!!!
In the UTEC boost maps, you can set the boost level (closed loop control) to whatever level you dependant upon TPS %.
I have a very simple setup on mine right now......0-50% throttle will only give me wastegate pressure....over50% throttle, and I have it set to 9 psi. that is obviously a very simple setup, but you can tweak the setting for every 10% TPS from 0-100% to whatever boost level you want.
Old May 20, 2007 | 09:34 AM
Julian@MRC's Avatar
Julian@MRC
The UTEC will not control Gear dependant boost, however their DTEC boost controller will, however, the 350Z does not have a Vehicle speed signal coming from the ECU, as it is transferred via the systems CAN bus system. The Z does have wheel speed sensors on each wheel, however all 4 signals are sent to the Body control Module/ABS/VDC computers where the signals are interperted and transferred via the CAN bus system to the ECU. We never tried to tap of just ONE wheel speed sensor to see if the gear dependant boost control would work..
Old May 20, 2007 | 01:04 PM
QuadCam's Avatar
QuadCam
on navi equipped vehicles, there is a Vehicle speed wire that is easily tapped into.......I know because I put a switch on it so that I can enter destinations into my NAVI while moving.
Old May 20, 2007 | 02:48 PM
Julian@MRC's Avatar
Julian@MRC
Correct, however I am unsure if it will provide the needed voltage the DTEC will need to see signal as I have not tested it..i am interested to see if this would work.
Old May 20, 2007 | 03:12 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
anyone get the blitz sbc-id and the power meter working together to control boost per gear? if so, please share any shortcuts/tips
Thanks
-sorry to hijack- but the topic is related
Old Jun 7, 2007 | 07:07 PM
MardiGrasMax's Avatar
MardiGrasMax
Thanks
Just checking the SBC iD Color out. It is of course a great boost controller. Adding the Blitz pressure and temp sensors and tapping other vehicle sensors and a wide band 0-5v input is very very cool. Having just the SBC iD Color would be much cleaner than having multiple gauges. Hooking in a VSS is needed to do the speed based boost. Any one figure this out yet? Where are you guys tapping RPM for somthing like this device?
Old Jun 7, 2007 | 07:19 PM
MardiGrasMax
In the FSM the factory dash gauges sends a 2P VSS signal to the NAVI unit, BINGO!!!
Old Jun 7, 2007 | 07:20 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
eboost will work perfectly. its pretty cheap and works just fine once you get it set up...
Old Jun 7, 2007 | 07:23 PM
roncfpz's Avatar
roncfpz
What about using the HKS EVC VI which allows boost to be tuned for throttle, RPM and/or vehicle speed?
Old Jun 7, 2007 | 07:26 PM
Audible Mayhem
My350z
ron, isnt it past your bedtime sir??
Old Jun 7, 2007 | 07:29 PM
MardiGrasMax
JT, where are we to tap RPM, off a coil pack signal?
Old Jun 7, 2007 | 07:30 PM
Audible Mayhem
My350z
yeah man, there are many places you can tap the rpm, that is one of them...
Old Jun 7, 2007 | 07:31 PM
MardiGrasMax
Is their a traditional rpm wire comming out of the ECM harness or the dash gauges?
Old Jun 7, 2007 | 07:42 PM
DaveFunction2ND's Avatar
DaveFunction2ND
Nope! With all the CANN bus components that signal is digital from the ECU to the dash and any other processor that needs the signal. The coil output is the best bet. You could potentially use the Greddy RPM adaptor to provide a single output if you Boost Controller/Window Switch/ETC needs a standard distributor style rpm type output.
Old Jun 8, 2007 | 08:51 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
+1
Old Jun 8, 2007 | 09:56 AM
DaveFunction2ND
It should be possible just needs to be tested and a few potential configurations played with.
Old Jun 8, 2007 | 10:06 AM
westpak's Avatar
westpak
SFZCC
The manual says you can do a 3d boost map with any of the two inputs.
Old Jun 9, 2007 | 01:40 AM
GTM's Avatar
GTM
Vendor - Former Vendor
EVC6 does NOT have gear dependent boost but it does have a 3D map with either RPM x Throttle OR Speed x Throttle. The HKS Easy Writer software is now available through an HKS dealer for an additional $129.00 and includes software and hardware to hook it up to your lap top. This software makes setting up the boost controller MUCH easier and also has logging capabilities, map tracing, etc.
I might be doing a write in the near future explaining in depth all the features of the EVC6 and how they work, its an awesome BC
Hope this helps,
-George
GT Motorsports
