Vortech. How To Take Off Pulley
Old Jun 16, 2007 | 04:03 AM
Barzten1's Avatar
Barzten1
Default Vortech. How To Take Off Pulley
Was recently thinking about swapping the 3.12 pully but couldn't figure out how to get it off. Do I loosen the bolts on each side of the pulley or is it something else. I felt like I was going to break it if I tried to take the bolts off. There are also some hex screws on the pulley housing. Do I mess with those? Thanks for any help. Jason
Old Jun 16, 2007 | 04:13 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
take both the cog belt and the main 6 rib belt off. loosen the bolt that goes through the 3.3 pull and into the cog belt pulley, back out the four allen heads on the cog belt side till they are almost all the way out and then you can slide the pulley off the front....
Old Jun 16, 2007 | 08:41 AM
THE TECH's Avatar
THE TECH
I wished it was that easy. Even with all the bolts removed, it may not just slide off...at least that's my experience with them. The key wedges the pulley on and may not come loose. You may have to get inventive to get it off. Just be careful since the grooves on the stock pulley will bend easily.
Old Jun 16, 2007 | 09:55 AM
Barzten1's Avatar
Barzten1
Yeah the bolts on either side of the 3.12 wont budge. Even tried an impact wrench.
Old Jun 16, 2007 | 10:10 AM
Audible Mayhem
My350z
yeah guys, an air gun will take it right off if you hold the back side with a wrench. if you back those bolts on the back side ALL the way out, the pulley comes right off, i promise, you have to slide the whole assembly back towards the rear of the car and the pulley will barely come off...
good luck!!
Old Jun 17, 2007 | 09:04 AM
booger's Avatar
booger
I loosen up the top 3 bolts holding on the blower . Then slightly pry over the blower to slide off the pulley .
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
