Which tuners trust 1 intank walbro for 550?
Old Jun 20, 2007 | 12:17 PM
USED's Avatar
USED
Default Which tuners trust 1 intank walbro for 550?
I don't, but I'd like to know what tuners would trust 1 intank 255 walbro (return system included) to sustain 550-ish WHP. I'm talking really trust reliably with minimal attention.
Thanks
Old Jun 20, 2007 | 12:24 PM
taurran's Avatar
taurran
Thanks
I'm not a "tuner" but I do. As long as it maintains consistent fuel pressure, why not???
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
I know Alberto is runnig 650 injectors and pushing 550 plus. I am sure 550 injectors will be fine.
Old Jun 20, 2007 | 12:36 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
No problem at all....done many many times by many tuners.
Old Jun 20, 2007 | 12:47 PM
QuadCam's Avatar
QuadCam
go with extra big injectors so that you can run a lower base fuwel pressure.
running a lower fuel pressure allows the walbro to be able to pump more fuel...*fuel pumps flow rates decrease as pressure increases.*
Old Jun 20, 2007 | 02:10 PM
phunk's Avatar
phunk
CJ Motorsports
quadcam hit it on the head. just get a set of 1000cc and FCON and your concerns are solved! lower pressure means higher pump flow capacity and more HP.
Old Jun 20, 2007 | 03:50 PM
USED's Avatar
USED
Just to clear things up, I never said 550cc injectors. I said 550 WHP. We're using 750cc injectors. I can see how you could make that mistake though.
Old Jun 20, 2007 | 03:55 PM
USED's Avatar
USED
The walbro 255 GSS 342 is only rated to about 500 crank HP by walbro. I've worked with walbro pumps for years. I like them, but I don't love 'em. I've had several failures lately (not under load, actually right out of the box). They get hot after extended use.
The pressure with walbros always falls off a few psi at idle after running for a while. I've witnessed this on Nissans/Hondas/Toyotas with single and twin pump set ups. I've always like the denso pumps, but you can't easily fit them into the Z/G housing.
Old Jun 20, 2007 | 03:56 PM
eagletanggreen
Got Track!!!!!
Woo! My bad speed reading again, but it looks like you got your answer.
Old Jun 20, 2007 | 03:59 PM
USED's Avatar
USED
With "extra large" injectors, regardless of fuel pressure, the idle will always suffer. You can only run a large injector (ex. 1000cc) at a certain low duty without it stumbling. Active A/F feedback can help, but only so much.
Old Jun 20, 2007 | 04:02 PM
USED's Avatar
USED
I agree, the FCON is an amazing box, but not in everyone's budget. And let's not forget...it's not user friendly and end user tuning/tweaking is not available.
Old Jun 20, 2007 | 04:10 PM
USED's Avatar
USED
Thanks for the input everyone.
So far, it seems everyone who posted about the single 255 in tank, trusts it. I guess I've just been soured by the 3 recent failures I've experienced...it sucks to get an entire fuel system built, turn the key and you see 0 fuel pressure. After the third failure, I now pre-test all of the walbros I use or sell. It was crazy. All the pumps turned on internally, the pump gears didn't spin.
We're using UTEC for EMS with no plans on changing out to another platform. We plan on the CJ single pump return system, just waiting on availability.
Old Jun 20, 2007 | 04:36 PM
Sharif@Forged
Forged Performance
Not with 1000cc low impedence injectors (HKS or RC Low Impedence), driven by an FCON, Haltech, or other EMS that can fire low impedence injectors. The cars start and idle like stock at 14.7:1'ish. You are correct, in regards to high impedence injectors.
If 550whp is your goal, a 650cc injector will more than meet your needs, with an RFS, and a walbro.
Old Jun 20, 2007 | 04:38 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Correction: 750cc, 40psi base fp, 580whp on a DJ with a fresh motor
Old Jun 20, 2007 | 05:00 PM
thawk408's Avatar
thawk408
Damn how did you get your fuel pressure to go that low? I can only go to 52ish.
Old Jun 20, 2007 | 05:06 PM
Sharif@Forged
Forged Performance
Drill out the yellow plastic swirl jet a little bit more. 1/8 inch maximum.
carlosG's Avatar
carlosG
I currently have 640rwhp in Hi boost with one walboro, and yes its something that I dont like cuz the injectors are maxing out. what I do is allways having at least 3 gallons of VP race gas in my tank tobe on the safe side and running onlow boost wich is 540rwhp. you should pm carlitos who is a friend of mine and member of this site so that he can tell you about his current solution to this problem he has 740rwhp with nos. and yes we both use RC750 injectors and UTEC.
wellcome to our neverending quest to find a solution to fuel without an FCON.
Old Jun 20, 2007 | 05:16 PM
USED's Avatar
USED
Yea...I've gotten so use to using saturated injectors. I just think of them as the street standard. Big peak and hold through a resistor box (ala AEM supra) still a ***** to "hand dial" for that magic stoich idle. I want to play with an FCON! Damn you PRO DEALERS !
550 wheelish is the low boost goal. but we all know how long that lasts
Thanks Sharif
Old Jun 20, 2007 | 05:17 PM
USED's Avatar
USED
Interesting...
Old Jun 20, 2007 | 05:54 PM
Sharif@Forged
Forged Performance
The new Haltech 350Z PnP unit (completely different from the current one) is a promising development. User/shop tunable and about a $2500 price point with wideband. It has sequential injection control (no batch fire like AEM), and drives low impedence injectors too (unlike AEM), controls DBW, and cam phasing too.
