My NEW 5" thick FMIC mounted... PE TT 6MT Sedan
Old Jul 3, 2007 | 08:35 AM
  #41
1superg's Avatar
1superg
sweet work Gurgen, now get a job...
Old Jul 3, 2007 | 08:41 AM
  #42
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Originally Posted by Hydrazine
If you are saying boost is regulated by a sensor before the IC, it should result in a pressure recovery at the plenum.
If the sensor regulates (hypothetically) to a maximum of 13 PSIG, and the new IC drops 0.5 PSID less than the old IC, this should result in a 0.5 PSI gain at the plenum.
This is only pressure. It does not say anything about the new density delta which is also likely to have improved too.
I see what you are saying.
Boost is regulated by the pre-IC pressure, which was previously elevated vs. post-IC pressure (purporting pressuredrop with the old IC at high boost levels). But won't improved (increased) DR make a direct comaprison impossible if you look/measure post-IC (in-manifold) pressure only.
DR=PRsys*[(Tamb+460)/(IAT+460)]
PRsys (systemi PR , including the IC press drop) will go up since the boost wil be regulated higher (due to less backup from the IC - so Pin/Pout relative to the IC is closer to 1) and due to the lower IC drop, while DR will go down due to lower IAT. Looks to me as though there are too many variables to make direct precise conclusions.
Be that as it may, the power increase is noticeable even without a change in timing. This is jsutified as the MFR (mass flow rate) has definitely improved, the only question is by how much.
MFR=VFR(2.703*Pamb)/(Tamb+460)*DR
VFR=volumetric flow rate (unchanged - fn of engine displacement and VE)
PRsys=systemic PR, including the IC pressure drop.
We'll know soon enough. Maybe I can come by one day to throw this baby on teh dyno, Tony. Let me know when it's good day to do that.
Old Jul 3, 2007 | 09:36 AM
  #43
1superg's Avatar
1superg
To all that don't know, Dr. Gurgen is about to embark on his medical career after taking his board exams. He is currently a bum, but not for long, he will dispatching Viagra, Cialis and other life saving drugs to me and other gimps.
So for all who know him for his automotive/tuning/science expertice, add brilliant doctor to the list.
Congrats on all your success!
Old Jul 3, 2007 | 09:56 AM
  #44
boostintt's Avatar
boostintt
dang that intercooler is big... nice job, car looking great.
Old Jul 3, 2007 | 10:46 AM
  #45
priscilla ls1's Avatar
priscilla ls1
Amazing great job Gurgen!
Old Jul 3, 2007 | 10:58 AM
  #46
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Nice work...and that was fast! We were just talking about this over the weekend, and bam..its installed.
Do you still want me to check on that Greddy charge pipe, or did you find a substitute?
Old Jul 3, 2007 | 11:33 AM
  #47
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Boost is regulated by the pre-IC pressure, which was previously elevated (Previously elevated? - It should be directly regulated to a fixed value you set at the boost controller regardless of IC delta P) vs. post-IC pressure (purporting pressuredrop with the old IC at high boost levels). But won't improved (increased) DR (DR?)make a direct comaprison impossible if you look/measure post-IC (in-manifold) pressure only. (I would think not. You have data loged the plenum pressure both before and after the new IC. Regardless of MFR, any change in IC pressure drop should be measurable at the plenum if the inlet pressure at the IC remains regulated and constant. And I would expect you are getting better pressure and MFR performance with the new IC. So you should be able to measure a change in plenum pressure and engine output.)
(if MFR changed by any substantial amount, it should register in your A/F ratio. You could back out a rough delta MFR from that)
Systemic PR and DR? Please define.
Old Jul 3, 2007 | 11:49 AM
  #48
GurgenPB's Avatar
GurgenPB
UltimateSleeper
LOL jef.....ROFL..seriously..
That's an inside joke, everybody, these guys think that I look like Alfred Molina...lol
Old Jul 3, 2007 | 11:51 AM
  #49
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Sharif,
I know! I talked to you the day before...and we were oly gonna test fit it that day..rest is history.
Yes, please do check on the price if you can please, just the big pipe and not the second one that bolts up to the maf housing, working on smth else to replace it (bigger MAF! ...more info later).
  #50
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Thanks!
Old Jul 3, 2007 | 11:58 AM
  #51
GurgenPB's Avatar
GurgenPB
UltimateSleeper
PRsys = Pressure Ratio in the system...i.e. pressure ration developed by the compressor minus the pressure drop in the ic (and technically the press drop through the piping...but ignoring that forthe moment).
DR= Density ratio. DR=PRsys[(Tamb+460)/(IAT+460)]
The temps are being converted to degrees R (Rankin)...hence the +460 vs +273.15 to obtain the absolute pressure. So all "T" values are in deg F, while P's in psi.
IAT is the post-IC temperature, after it was heated by the compressor and cooled down by the IC (again, other heat transfers ignored).
IAT is sometimes referred to as Tout, while Tamn is referred to as Tin, but I changed things around a bit for clarity (in case of Tamb), and to avoid confusing IAT with Tout (whereas Tout is used for comrpessor outlet air temps).
Old Jul 3, 2007 | 12:02 PM
  #52
Hydrazine's Avatar
Hydrazine
Happy 4th of July everyone!
I'm out'a here. Going off to San Diego with the wife and daughter.
Old Jul 3, 2007 | 12:03 PM
  #53
Chebosto's Avatar
Chebosto
looks god gurgen! wow. that core is HUUUGE.. who makes it?
Old Jul 3, 2007 | 12:07 PM
  #54
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Have fun Tony, call me when you get back.
Old Jul 3, 2007 | 04:20 PM
  #55
athenG's Avatar
athenG
The first few pages was great then this You guys are giving me a headache with all this formula
Good thread and very informative. Only if you can absorb all these DR, PR and T stuff
Old Jul 3, 2007 | 04:34 PM
  #56
r0mey's Avatar
r0mey
lookin very good that core is fire!
Old Jul 5, 2007 | 01:39 PM
  #57
Mr B's Avatar
Mr B
Hey Gurg, long time no see.
Grats on the 6MT and also on that phatty I/C! Hope all is well.
Old Jul 5, 2007 | 01:41 PM
  #58
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Thanks buddy!
Old Jul 5, 2007 | 08:10 PM
  #59
Zheaven's Avatar
Zheaven
hey do you live near montrose?
nice sedan btw.
Old Jul 5, 2007 | 11:33 PM
  #60
GurgenPB's Avatar
GurgenPB
UltimateSleeper
nice sedan btw.
3 miles away
