Blown Turbo :(
Old Jul 13, 2007 | 04:00 PM
DJames's Avatar
DJames
Originally Posted by Jrooy
DJames ... I have the Greddy TT kit. The turbo I bought is a TD05 - 18G. The cost was $1,400+ each.
Are you saying that the price for the GT35R is wrong ?
Old Jul 13, 2007 | 04:13 PM
Jrooy's Avatar
Jrooy
I think the Greddy turbos are not the same as the GT35R. I was just stating what it cost me to replace the Greddy turbo. I don't know the price of a GT35R.
Old Jul 13, 2007 | 04:17 PM
DJames's Avatar
DJames
Dang thats insane. Yeah man, my turbo only has 5,000 Miles Max on it. I just don't how they could have gotten messed up.
Old Jul 13, 2007 | 04:37 PM
Jrooy's Avatar
Jrooy
I hear ya. My turbos blew due to a blocked oil supply line. I got a little over 100 miles on the first one and less than 10 miles on the second one. I have around 4,000 miles since we figured out the problem and everything works great. I hope you can figure out what happen to yours ... so you can have a little peace of mind and not worry that it will happen again after you fix it.
Old Jul 13, 2007 | 04:48 PM
DJames's Avatar
DJames
Yea, I hope i figure out the problem as well so i can have a peace of mind when i install the new Turbo.
Old Jul 13, 2007 | 05:58 PM
boostintt's Avatar
boostintt
my buddy had one of his tt rebuilt for about $300.. he sent them off and in a few days problem fixed. i will try and see if i can get you the info of wehre he send it to.
Old Jul 13, 2007 | 08:58 PM
DJames's Avatar
DJames
That would be very helpful. Does he have the APS ST Kit ?
Old Jul 14, 2007 | 08:55 AM
DJames's Avatar
DJames
One more question, since my Turbo needs to come out to replace the cartridge should i install a Tial External Wasgate ? What is the benefits oh having it and how hard is it to install it ?
Old Jul 14, 2007 | 11:50 AM
Darkest's Avatar
Darkest
DJames...You said you got Greddy TT for $1,400 a turbo? Did you get anything else with that kit? Ex. Intercooler, fuel pumps etc
Old Jul 14, 2007 | 06:55 PM
Jrooy's Avatar
Jrooy
Darkest ... the $1,400 was to replace a blown turbo, not the cost of the kit. I bought the Greddy TT kit with intercooler for $5,400. The Greddy kit does not include everything you will need for a good setup (gauges, BOV, fuel pump and return).
Old Jul 14, 2007 | 07:06 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
On a APS ST kit you can only install a new wheel set. they are bb turbos cant rebuild them Greddy turbos are non bb turbos there for you can rebuild the whole turbo. I have seen the connections come loose that powers the external pump to supply the oil to that turbo come loose and have the turbo fail, just because the turbo is getting some oil doesnt mean its getting enough oil. A tial waste gate is only helpful because it holds the boost more accurately than a internal. If you are running on a stock motor i would not worry about a external waste gate. They only come in on high boost applications and even then it all depends on how you plan on using the car.
Old Jul 14, 2007 | 07:17 PM
DJames's Avatar
DJames
Hey Jarred,
Thank you for your post and PM. I will contact you shortly. Now about the oil pump and the connections how can you tell if the connection is coming loose? Is there any signs or you just need to listen for it or is there a way to test it. Let me know thanks.
Old Jul 14, 2007 | 07:21 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
well the aps kit if i remeber right comes with those crappy little plastic wire taps and you can hear it run if you put the car in the air and have someone jiggle the wires alittle and if they're loose youll hear the pump cut off and on in a weird pattern. I have seen them install to the point where they stay on and oil leaks into the intake and starve it for oil and kill the turbo even though oil is flowing through the turbo.
Old Jul 14, 2007 | 07:34 PM
DJames's Avatar
DJames
hmm.... so is there a way to secure this? from happening ?
Old Jul 14, 2007 | 07:52 PM
TerraNova3's Avatar
TerraNova3
If it was me I would try to get a new turbo, A better one.
Old Jul 14, 2007 | 08:01 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
the turbo is fine you could solder them in to get a for sure connection but its a B*tch to solder in that small space by the fuse box under the battery cover.
Old Jul 14, 2007 | 08:40 PM
tig488's Avatar
tig488
a faulty pump doesnt cause the turbo to make grinding noises. IF it does, its gone, no chance of it being good anymore.
to see if the pump is working, turn the key to ACC and have somebody listening under the passenger side of the car, you should hear it come on. but it will only run about 5 seconds.
as far as the turbo is concerned, you cannot rebuild bb turbos, and yes a cartridge costs 1000...
BUT, depending on what is wrong with it, you might be able to get a brand new cartridge from TurbosDirect for 400, and yes, thats for ball bearing units. if parts can be salvaged, they will do a cartridge exchange for any garrett setup for 400. you must call them and tell them what is wrong with yours, if they say ok, you send them yours, and they send you a brand new one, i did this months back.
http://turbosdirect.com/
Old Jul 15, 2007 | 10:32 PM
  #38
DJames's Avatar
DJames
I was on Garrett's site today to check out some turbo's and stuff. But i was wondering what Cartridge do i order cause there seems to be a lot of GT35R Turbos but just different version. Here is what is listed on their site.
GT35
GT3571 - 731413-1
GT3582R - 714568-3
GT3582R - 714568-1
GT3582R - 714568-2
is all the cartridge they use the same ?
Old Jul 16, 2007 | 10:02 AM
  #39
tig488's Avatar
tig488
just order a 3582 cartridge, the 1,2,3 at the end designates turbine housing AR i believe, but that doesnt affect you.
Old Jul 16, 2007 | 10:31 AM
  #40
DJames's Avatar
DJames
Thanks Tig !
