MC-Performance 6MT 350Z TT First Attemt at the Drag
Originally Posted by chriskabobbers
congrats on the great run! but I think the fastest TT on the drag thread was 10.375 sec
Originally Posted by one350zfan
The 10's posted on the list are w/ GM tranny. However, Jeremy did run a 10 sec pass w/ the 6MT.
http://www.performancefactory.com/vi...ckrun11-17.wmv
Originally Posted by SMS Tuner
I just checked th thread but the 10sec run he was using Nitrous
PF also ran a stock block single turbo at 11.0 sec.
we have 11.0 on the stock block with no nitrous.. thats with the 6mt.
i ran a bunch of 10.8s and tons and tons of 10.9s on the stock tranny with a messed up clutch. with no nitrous..
keep up the good work but you will have a lot to catch here soon , even on the 6MT..
I was referring to the list sorry.
PS: the link is not working
yeah if you look at that list, my run got bumped up cause you are only allowed to have one time on each list.
my tech has his run in the single turbo section.. 11.0 at 122 or 124 i think.
First of all i would like to thank you but, i was referring to the TT 6MT.
Originally Posted by Hal@IP
Nice run, especially on 14psi! It is always good to see people hitting the track
The car is own by Silver Nismo with the following Specs when at the Track:
1- Built Engine with:
- Arias low comp pistons
- Eagle Forged Steel Rods
- ARP L19 Head studs
- ARP Main Studs
- HKS Head Gasket
- Ported & Polished Heads
- JWT C2 Cams
2- Greddy TT kit
3- HKS F-Con V PRO
4- HKS Injectors
5- HKS Dual Exhaust with custom 3in modification right after the turbos.
6- HKS EVC5 boost controller
7- HKS Oil Cooler
8- HKS Twin Power DLI
9- HKS 2step colder Spark Plugs
10- KOYO Type R Rad
11- AAM Return Fuel System
12-Wellbro In tank Fuel Pump
13-Innovate AFR Linked to the F-Con V PRO
14-RPS Clutch (toasted)
15-TEIN Lowering Springs
16-5AT Rear Differential
The Car is a full wight Track Edition 350Z + Full Nismo Body kit and a 195lb Driver (my Self
).I would like to take this opportunity to thank Mr. Ali Known as: Silver Nismo in this forum for allowing us to drive his car at the Drag Strip.
Originally Posted by Alberto
Nice run, but still a way from Jeremy. Post the time slip, 60ft, 1/8 info, vehicle weight and some power numbers please...
Jeremy ran 10.404@134.00mph.
Originally Posted by Gman2004
I am missing something. He ran 10.379 @ 214.74 kmh.
I ran 11.27 at 130MPH. the car in the other lane ran the other number.
Nice runs SMS tuner. How much whp is the car putting down?
What was the 60ft, 1/8 time/trap??? And were you able to stay in 4th with the 3.3FD and the tire you were running?
