Golden Eagle Vacuum Manifold?
Old Aug 26, 2007 | 09:46 AM
failsafe306's Avatar
failsafe306
Thumbs up Golden Eagle Vacuum Manifold?
http://www.goldeneaglemfg.com/street.html
Any thoughts on this? I'm thinking about ordering one to eliminate all of the "T's" in my turbo setup. From the looks of it, you just get a pressure signal from the intake manifold, then hook up your boost gauge, MAP sensor, wastegate, etc all directly up to the Vacuum Manifold. Looks pretty cool to me
Old Aug 26, 2007 | 09:49 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
I looked at that a long time ago. Its kind of ugly though especially with their Eagle logo. I managed to get one that was a black block without any logos. It was a while back but I think I found it on eBay - cheap as I recall.
Old Aug 26, 2007 | 09:51 AM
failsafe306
I agree, that logo isn't too pretty, but I'm thinking the other side is most likely blank.
Old Aug 26, 2007 | 10:21 AM
THE TECH's Avatar
THE TECH
Seems to be a good way to go even if it isn't all that attractive.
Old Aug 26, 2007 | 10:28 AM
failsafe306
I found a different brand on the 'bay, but it was even uglier.
Old Aug 26, 2007 | 10:43 AM
MIAPLAYA's Avatar
MIAPLAYA
I found this:
http://www.bloxracing.com/prod_vacuumManifolds.asp
You can get it in black to make it less noticeable. I hate to bring them up but AAM's throttle body spacer could also be used for this.
http://www.alteredatmosphere.com/mm5...de=350Z_INTAKE
Old Aug 26, 2007 | 10:48 AM
failsafe306
nice find Mia
Old Aug 26, 2007 | 10:51 AM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by failsafe306
nice find Mia
Why thank you. You could also ask a local machine shop to make one. Just need a small block of aluminum and have them machine out however many ports you need and tap them to 1/8" NPT. You could then powder coat, polish it, etc. Hell they could even put "Failsafe Motorsports" on it if you want them to.
Old Aug 26, 2007 | 10:58 AM
failsafe306
Then I could become a sponsor and sell them $$$$ lol
Old Aug 26, 2007 | 11:10 AM
MIAPLAYA's Avatar
MIAPLAYA
Seriously.... Well if you get a machine shop that's willing to make a nice piece for cheap you could. BTW if you are looking to hide the vacuum block you can drill and tap a couple holes in whichever vacuum manifold you are looking to get thats just deep enough for a mounting bolt and and then mount it in the battery or brake fluid compartments. The sheet metal for those compartments is really thin and easy to drill through. If you put it in there all you would say from the engine bay is two bolts which look factory going into the sheetmetal of the compartment. A buddy of mine did that for his Zeitronix MAP sensor, Evap solenoid, etc... That's where I have my MAP sensor too.
Old Aug 26, 2007 | 01:46 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
I have used the ones from McMaster which come in black with nothing on them. You'll have to hunt around a little to find it though unless I can dig up a part number.
Old Aug 26, 2007 | 02:17 PM
failsafe306
Thanks Hal
If you happen to find that part number feel free to post it up.
Old Aug 26, 2007 | 02:26 PM
Dynosty's Avatar
Dynosty
Thanks Hal
I found them. They offer them in all different setups, but a 6 outlet manifold starts around $15 for black anodized 6061 aluminum. Follow THIS LINK to check them out. You will need barb fittings, which mcmaster also carries.
Old Aug 26, 2007 | 02:39 PM
failsafe306
Nice, thanks!
Old Aug 26, 2007 | 03:05 PM
NETSHARK's Avatar
NETSHARK
You can try Vibrant Performance their Vaccum Manifold looks so cool
http://vibrantperformance.com/catalo...d1ad07e0c893f0
I Believe that QuadCam Got it, he can comment on it.
Old Aug 26, 2007 | 03:47 PM
QuadCam's Avatar
QuadCam
Good recall Netshark.
I do have the Vibrant unit. It works just perfectly.
Old Aug 26, 2007 | 06:22 PM
2slo2bfurious's Avatar
2slo2bfurious
http://www.a1manifolds.com/?OVRAW=va...ID=25720526522
I used one of these, even cheaper, and lots of options... no logo either...
Old Aug 26, 2007 | 06:47 PM
MIAPLAYA's Avatar
MIAPLAYA
Good call on McMaster Carr Hal. They have EVERYTHING..
Old Aug 26, 2007 | 09:56 PM
phunk's Avatar
phunk
CJ Motorsports
The plenum is thick enough to just drill and tap one or two 1/8 NPT or BSPT ports on by the brake booster. The APS plenum is extremely thick to drill even nicer ports in its casted in additional injector bungs that never got used as they had originally planned for their extreme fuel system.
My car only has one extra vacuum port that I added to the manifold, for the boost controller. The boost gauge has a single T off the EVAP line going behind the throttle body. The stock vacuum port on the front goes to the blow off valves.
Old Aug 27, 2007 | 08:00 AM
g356gear's Avatar
g356gear
I hear you can use one of those plastic aquarium air meter blocks. You can even adjust the amount of vacuum you want each accessory to see.
