Vortech VS. Single Turbo
Old Aug 30, 2007 | 11:21 AM
  #41
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by Nexx
+1, its the massive torque mid end that puts a lot of stress on the VQ that usually does them in.
bearings failure have happened on boost levels over 10-12 psi ...ie over 400 lbs of tq
8.5-9psi is "safe" on stock vq
there is the over reving.... missshift but that can break any engine using any FI application
Still less power = more "safety" but @ a certain pSi they are both safe anyways so id take the one that puts out more power ...@8psi
Old Aug 30, 2007 | 11:32 AM
  #42
davidz33's Avatar
davidz33
Here's my question.
Even if the engine is built with forged internals, that just means the engine is more reliable than stock, but it won't be invincible, right?
Is there any occasion where built engine blew up with a mild tuning that some stock engines can handle(at least for a while)?
Old Aug 30, 2007 | 11:35 AM
  #43
sentry65's Avatar
sentry65
the burninator
what sort of 8 psi are we talking here?
8psi with 3.5 inch test pipes and dual 3 inch exhaust and cams?
or 8 psi on a stock car, maybe an exhaust?
Because they're going to have hugely different power/tq numbers but still hit 8 psi
psi isn't really a measure of power, it's a measure of resistence of air flow
Originally Posted by davidz33
Here's my question.
sure, nothing is ever invincible
I'm sure someone somehow blew their built engine with a mild tune. It could be due to all sorts of things
Old Aug 30, 2007 | 11:38 AM
  #44
IIQuickSilverII
+1 but you have a greater chance on longetivity on the engine.....asuming everything gets done right in the first place
Old Aug 30, 2007 | 10:48 PM
  #45
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Here's my question.
Forged engine is definitely stronger than the stock engine and can handle alot more abuses and horsepower... BUT.. forged engine can also fail if the builder didn't build it with precision. It seems as though most of forged engines fail due to perpheral component failures or human errors (mapping).
Old Sep 1, 2007 | 09:11 PM
  #46
davidz33's Avatar
davidz33
OK, so when the engine fails due to too much pressure, it's the internal part that goes wrong, but never the block itself, right?
Old Sep 2, 2007 | 12:56 AM
  #47
sentry65's Avatar
sentry65
the burninator
if a rod breaks, the block is ruined
I haven't seen a case where the vortech caused rod failure that the owner wasn't asking for it
Old Sep 2, 2007 | 05:12 PM
  #48
04treefiddy's Avatar
04treefiddy
Jp.. On the 3.12 pulley with a plenum spacer, 2.5 exhaust(y pipe style), test pipes, walbro and a tune(by sharif) i made 395/325 on a dynojet.
Old Oct 30, 2007 | 02:41 PM
  #49
Blwn_By_Twins's Avatar
Blwn_By_Twins
Originally Posted by leeboyNY
Look at my sig... and learn from other people's mistakes, Once you taste boost, you will want more.. So.. be wise and start saving up for the forged engine + TT setup and do it all at once. If you want boost NOW, and plan to build your engine later, I highly suggest going TT. It's extremely easier to raise boost with TT than SC.
THANK YOU, THANK YOU, THANK YOU, THANK YOU!!!!!!!!!!!
I've been searching and reading for almost a week trying to find my answer and you, Leeboy, have given it to me. I am also looking to build my motor by next summer and wasn't sure which route to go, SC/ST or TT. Now my only fear is, as it was put to me by a friend, with a TT setup there are more parts to break! LOL
350Z_Al
Oct 29, 2020 07:44 PM
fst100
North East
Sep 8, 2015 11:37 AM
