Almost back on the road....... new and improved
Originally Posted by George@GTM
We usually spec all our builds with 8.5:1 CR unless requested otherwise by customer.
-George
GT Motorsports
-George
GT Motorsports
I heard that lower CR gives you faster spools but I am not very knowledgeable in this area. . . .
Thanks
hey Ziv:
- can you ellaborate on why the UR PUlley caused a crank failure?
- I also heard that the pathfinder mod can actually decrease the flow of coolant through the block (affecting velocity of the fluid or something)... have you heard this?
Originally Posted by Devil Z
Does 9:1 CR give you better response than 8:5:1?
Thanks
Thanks
Originally Posted by Gman2004
Man, it seems like your car is taking forever to get back on the road. I am glad to see you're almost done. I am sure you can't wait any longer.
Congrats Aaron, that's great news!
My motor is finally getting broken in and should be tuned very soon. The way things have gone since February, you'll still probably be up and running before me though.
Originally Posted by booger
So Arias makes two different pistons ? One just for your shop and one for every one else ? Or is this just the new design they make ?
I would say, that both the GTM spec, and FP Spec pistons are the best pistons available for our cars.
I am hoping to have everything tuned and done by the end of the month.
Good luck on the finished build! I'm sure it'll work out well this time. You seem to have everything planned out and covered (down to the floor mats!).
Mind if I ask which ebay special oil cooler you went with?
HEY JUST CURIOUS, since you are using lighter pistons, is it also necessary to remove an even amount of weight off of the lobes on the crank to keep the engine balanced? Maybe not necessary since its such a small amount?
Its nice to see that you almost got the car back uo and running aaron. Wen you do get it running we will have to meet up im sure it will be a beast. It will make my 9psi car feel slow lol. But good luck with finishing it up i hope it all goes well man.
Originally Posted by Zivman
I meant to ask irshad about your car last week, but unfortunately I haven't spent enough money with him yet for him to return my call
He must be busy moving these days.
