Alternator going bad with F/I, anyone?
Old Sep 3, 2007 | 02:28 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Question Alternator going bad with F/I, anyone?
Figured this was the best place to ask this question.
Just wondering if this has been seen in many other forced induction/high hp 350z's/G35's from excessive heat...
I had to replace my alternator about 3 months ago, stock one dies, had a few hours warning, the battery light flashed periodically, then came on solid, then I was walking.
So, 3 months later, a few days ago, the partial throttle cruising is a bit choppy, almost like it is misfiring, notice my dash battery light is flickering as I accelerate, and the factory voltage meter drops at/ slightly below 12v.
I have already checked all connections to alternator, starter, battery, belt tension. No sign that the belt is slipping, but I can usually only make the dash battery light/voltage drop occur when revving it wuickly to 5000+rpms, then it seems like after it heats up, after driving for a good 10 minutes, it will present the same symptoms intermittently at various rmps/verious loads...my conclusion- swap in a new alternator...
Any ideas, prior issues with your alternators failing?
Thanks
Old Sep 3, 2007 | 02:30 PM
failsafe306's Avatar
failsafe306
Have you made sure the 12v wire going from the alternator isn't damaged or burned anywhere along the line?
Old Sep 3, 2007 | 02:39 PM
Jay'Z's Avatar
Jay'Z
My alternator is fine.. But I would check the battery connections are strong.. You should have almost 14v most of the time..
Old Sep 3, 2007 | 02:45 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
inspected all the lines, everything checks out... i figured something was loose at first, since the intermittent nature of the problem... but i am starting to think that heat is killing my alternators, i know a common problem on some other F/I vehicles some friends of mine own...
keep the feedback coming, thanks
Old Sep 3, 2007 | 02:47 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
it makes 13.9V when checked with an external voltmeter, but at the certain times that it drops the voltage, per the stock in cabin volt meter, it shows 12v or a bit under, as if the alternator completely shuts down for those moments
all connections to battery are good
Old Sep 3, 2007 | 02:49 PM
Jay'Z's Avatar
Jay'Z
You may need a batt with higher cranking amps.. Or a better alternator.. Do you have a system too?
Old Sep 3, 2007 | 02:52 PM
failsafe306
I'd disconnect the 12v line from the alternator and meter the resistance on both ends, and try shaking the wires around to see if the resistance changes. The copper on the inside of the jacket could be damaged and get worse when it heats up.
Just a thought
failsafe306
Oh, and have you tried a new battery? Electrical problems suck....
Old Sep 3, 2007 | 02:53 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
I do have a system, have a capacitor, even though I've heard they are worthless, to some saying they are great and will resolve the problem that I am experiencing. The issue occurs regardless of whether the stereo is on or not
The battery holds its 12.5V consistantly, and, forgot to mention, replaced the battery 3 months ago as well, at the same time as the alternator
Old Sep 3, 2007 | 02:54 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
3 month old battery
Old Sep 3, 2007 | 02:55 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I can see high heat possibly melting the copper wraped around the stator inside the alternator,but where it sits it should have enough air flow to not be a problem.If the next alternator fails i would take it apart and see if anything was melted.
Jay'Z's Avatar
Jay'Z
Originally Posted by 350zDCalb
3 month old battery
Battery specs pls??
Old Sep 3, 2007 | 02:56 PM
failsafe306
The battery voltage should be higher, closer to 14vdc. Did I read right, that you checked the votage coming off the alternator itself?
Old Sep 3, 2007 | 02:58 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
soory, 12.5V when the car is not running/alternator not spinning
13.9 with car running
i always thought an alternator typically works ot it doesnt, so hopefully it is some line somewhere, i'm still searching, i hate electrical problems.
Old Sep 3, 2007 | 03:00 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Battery specs pls??
oh, sorry, nothing too fancy, Autolight platinum 96P, better than the factory battery, but not anything outragous, thing is, no issues like this for a few years on the stock battery, and 3 months now on this one...i dont think that is the determining factor here...
failsafe306
Sounds like your battery. It should be holding 13.9, even with the car off.
Old Sep 3, 2007 | 03:09 PM
Jay'Z's Avatar
Jay'Z
Actually the factory batt is better than u think..
I couldnt find that batt... When I say specs I was asking how many CCA (cold cranking amps) and RC ( Reserve Capacity)..
Old Sep 3, 2007 | 03:11 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Think you are right... I just tested somethign i hadnt yet...
I disconnected the wire coming fromt he alternator to the battery, testing that by itself, it reads 15.5V.
I turned the voltmeter so i could see it as i got in my car to rev it up...as i revved it, the alternator read up to 16V..so the alternator is not cutting out intermittently as it appeared... guess the battery sucks,
who has experience with a good battery, recommendations?
Thanks
Old Sep 3, 2007 | 03:12 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
yah, seems like it, what kind of battery do you run?
Old Sep 3, 2007 | 03:23 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
what are the specs of the factory battery? CCA/RC?
