Vortech blower removal
Old Sep 11, 2007 | 11:36 AM
CaneZMD's Avatar
CaneZMD
Default Vortech blower removal
My AC died and the only way to sniff all the lines and compressor etc. is to remove my Vortech blower. I installed it myself, so I'm pretty handy.
My question is this: Can the blower itself be removed WITHOUT removing the mounting bracket?
Basically, it's mounted on the bracket by 4 bolts. One seems to be pretty low, is it reachable?
Thanks
Old Sep 11, 2007 | 11:38 AM
iStan's Avatar
iStan
ZR
I think the bracket will probably be easier. It's tight in there. I remember looking at it, but we said the hell with it and removed the bracket.
Old Sep 11, 2007 | 11:48 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Remove the whole thing together
Old Sep 11, 2007 | 12:18 PM
booger's Avatar
booger
Yes its easy to remove the blower with out the bracket . You access the bolts [ lower ones ] threw the wheel well . Take off the tire and the front plastic wheel well [ easy ] Once off you will see and be able to get to the oil feed line and the fourth bolt holding the blower on the bracket . The blower even drops down into the wheel well to remove it .
Old Sep 11, 2007 | 01:06 PM
CaneZMD's Avatar
CaneZMD
Sweet, thanks booger.
I want to do this with as little labor as possible, because the only reason I'm taking it out is to find a leak with the AC and fix it.
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
