need some help
Old Oct 23, 2007 | 11:25 PM
screaming_350Z's Avatar
screaming_350Z
Default need some help
i have a 350Z with a 4.3L AEBS Stroker Short Block with dart sleeves and cosworth heads and i'm looking to add a APS extreme twin turbo kit does anyone know how this will work out and how many ponies am i looking at gaining does anyone know where to buy a tranny that can handle the much power any info will help thanks
Old Oct 24, 2007 | 04:15 AM
dutchboy's Avatar
dutchboy
The APS Extreme has worked pretty good on a couple cars with the GTM 4.2 stroker kit. If you search the FI section for threads started by Nitrousz you should find his thread about his build and some dyno numbers. I think GTM's car did 855whp with the 4.2/APS Extreme combo. As far as your power levels, who knows. It all depends on if you will run pump/race gas, meth, boost levels, etc. You should make some great numbers though with your setup.
Old Oct 24, 2007 | 04:42 AM
westpak's Avatar
westpak
SFZCC
depends, if you want top end power or a good power curve, the APS Extreme is too laggy when compared to the regular kit, or better yet get a Greddy, much better responding than he APS Extreme.
Old Oct 24, 2007 | 05:02 AM
JAM3Z's Avatar
JAM3Z
Phenom
you have a widebody z? pics please!
Old Oct 24, 2007 | 06:50 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
We have used the AEBS 4.3L kit before, and I think the APS extreme would be a great match to it.
What are your goals for the car - daily driver, drag race, etc?
Old Oct 24, 2007 | 07:48 AM
Zridder19's Avatar
Zridder19
Sounds interesting... subscribing
Old Oct 27, 2007 | 08:29 AM
screaming_350Z
i would glady load but i can't get my damn camera to upload i can built cars put cant work a carmera.Go to CARBON CREATIONS its the W1 WIDEBODY KIT damn near the same but my car is completly painted no carbonfiber is shown
Old Oct 27, 2007 | 08:33 AM
screaming_350Z
what i want to do is to be able to hook up my laptop and have some setting saved so i can use it for a couple of different races. does anyone know what is max psi or kPa for this kit because i don't want to buy a 20psi boost guage and then find out i can run 32psi
Old Oct 27, 2007 | 08:48 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I would agree with you if you're talking about stock 3.5L displacement. My understanding from GTM is that the Extreme kit responds well with a stroker kit.
Old Oct 27, 2007 | 10:20 AM
Devil Z's Avatar
Devil Z
What sized turbos does the Extreme kit use? I was given the impression that it used one of the GT28's Garrett offers.
Old Oct 27, 2007 | 11:03 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I asked Sam at GTM some questions about the Extreme kit back in May. This was his response to me via PM about the size of the turbos:
"the turbo in aps extreme kit are 50/lb per mint they a hybrid gt3071 ,aps always try to confuse us by mixing things around."
