Questions About Water Methanol Alcohol Injection - Post Them Here
Old Nov 6, 2007 | 07:34 PM
athenG's Avatar
athenG
Originally Posted by AIS
Are you running the UTEC? If so you can simply use our Stage 1 system and use the UTEC to control the water methanol injection system.
I like this part but how you integrate your kit with Utec? Is it only by boost?
Old Nov 6, 2007 | 08:38 PM
aloh's Avatar
aloh
Hm...i need schooling on the basics. What exactly is meth/alcohol injection? How does it work?
Old Nov 7, 2007 | 03:18 AM
westpak's Avatar
westpak
SFZCC
good reading http://www.alcoholinjectionsystems.c...icle_info.html
Old Nov 7, 2007 | 01:34 PM
xav_350z's Avatar
xav_350z
Thumbs up
i still didn't install the utec, still runing the SS BOX that came with the vortech.
btw i already bought a snow performance kit (stage II ) 2 months ago ....
Old Nov 7, 2007 | 02:53 PM
AIS's Avatar
AIS
Sounds good. What container are you using with the Snow kit? How long did it take you to install that system? How do you like the system and what would you change about it?
Old Nov 7, 2007 | 03:38 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Still waiting on my response...
Old Nov 7, 2007 | 04:43 PM
mok5's Avatar
mok5
For a Stillen kit where the 7th injector is already near the throttle body, where else can i locate the nozzle, or is it safe to place it near the 7th injector?
Thanks!!
Old Nov 7, 2007 | 06:20 PM
AIS's Avatar
AIS
Originally Posted by Alberto
Do N20 (wet) and meth get along? If so which one should be mounted closer to the TB? Recommended or is this pushing it? Welcome to the forums btw..
Yes, Nitrous and water/alcohol get along quite well.
Matter of fact, by running water methanol injection you will not have to run nearly as much timing retard or any depending on the size shot your going to be using. Remember, nitrous accelerates the combustion process which is why the ignition retard. Adding a water methanol injection helps stabilize the combustion process and give you that added octane increase to help prevent detonation, and cool the exhaust gas temperatures.
This is the short answer. But "yes" the two get along quite well. Hope this answers your question.
Old Nov 7, 2007 | 06:40 PM
athenG's Avatar
athenG
What about my question?
Old Nov 8, 2007 | 05:09 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Which one gets mounted closer to the TB? Id imagine the N20/fuel needs more time to atomize so would need to be further back than the meth? Thoughts?
Old Nov 8, 2007 | 05:53 AM
AIS's Avatar
AIS
You mount the N20 so that it sprays behind the methanol mixing with it. The N20 is going to be injected under a much higher pressure then a water/methanol injection system so place it before it.
Old Nov 8, 2007 | 07:07 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Some questiuons I had from your for sale thread:
So, if I understand this right, you have to run a fluid line from the trunk to the engine bay, as well as a vaccuum line from the engine bay to the trunk, and provide a +12V constant and ground line?
Couple of questions, then:
1. Whats the current draw of the pump?
2. Does the pump only activate under boost (positive pressure on the vaccuum line)?
3. Is it variable by boost, or is it one set pressure for any boost?
3a. If it is variable by boost, is it user programmable, or factory set?
4. Does it also have a +12V switched, so it knows when the engine is on, or is there a relay involved that I need to buy, or is there a driver mounted switch? Or is there something else entirely?
__________________
Old Nov 8, 2007 | 01:53 PM
xav_350z's Avatar
xav_350z
the one that came with the kit.
the kit is still in my garage, i'll install it next week maybe, i had to wait for the UTEC. (which came in couple of days ago...)
i'll keep u posted
Old Nov 9, 2007 | 06:01 AM
AIS's Avatar
AIS
i'll keep u posted
If you ever want to switch over to stainless steel lines replacing the plastic tubing give us a call.
Old Nov 19, 2007 | 07:47 AM
AIS's Avatar
AIS
www.alcoholinjectionsystems.com
Old Nov 19, 2007 | 07:52 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Thanks for answering my questions...............
Old Nov 19, 2007 | 09:09 AM
athenG's Avatar
athenG
Thank you for also answering my question This thread made it easy for me to pick which kit to get since the other one answered all my questions and PM's.
Old Nov 21, 2007 | 10:07 AM
  #38
AIS's Avatar
AIS
1. Whats the current draw of the pump? 4 amps
2. Does the pump only activate under boost (positive pressure on the vaccuum line)? The Stage 1 systems are boost activated only while the Stage 2 systems can be activated by boost, EGT's AIT's, TPS, Mass Air Meter or any other 0-5 volt sensor on the engine.
3. Is it variable by boost, or is it one set pressure for any boost? The Stage 1 system is a non-progressive flat rate system. The Stage 2 is a variable flow progressive system metered off of the signal you choose to run.
3a. If it is variable by boost, is it user programmable, or factory set? This is user programmable.
4. Does it also have a +12V switched, so it knows when the engine is on, or is there a relay involved that I need to buy, or is there a driver mounted switch? Or is there something else entirely?You would hook the system up to a 12v ignition on power source or you can use a relay.
Let me know if you have any other questions. We try to answer all the questions in a timely manor but due to the volume of emails and phone calls we receive directly we may be busy helping customers. The best way to reach us is by phone 1-801.447.2559, or by emailing us directly at info@alcoholinjectionsystems.com
Old Nov 21, 2007 | 06:09 PM
  #39
mok5's Avatar
mok5
Anyone have any idea about this??
Thanks!!
Old Nov 23, 2007 | 10:49 AM
  #40
AIS's Avatar
AIS
With the Stillen supercharger system, you would place the water methanol injection nozzle in the plastic tubing just before the throttle body. Stillen is using an Eaton compressor which is quite common on many other vehicles which we work a lot with.
