My horsepower saga
Old Nov 19, 2007 | 12:29 PM
  #61
taurran's Avatar
taurran
Originally Posted by D350Z10
I have the exact same problem man.... there were no answers Sharif did every sort of trial and error but couldn't come up with anything, my compression was fine to according to the leak down test. So now The enitre motor is being tore down again and rebuilt. He thinks that either the valves or ringlands could be the problem. This has been such a huge headache, 5 + months and still no running car. I only made power up till 12psi and after that there was nothing. Ignore all these people that are saying its cause of your stock components... they dont know what there talking about, even with stock heads and cams your car should still produce good power. 16...17 psi and only 509hp... somthing is serioulsy wrong.
What's funny is that my car is doing about the exact same thing. So far we've been looking at the turbo system but wouldnt it be funny if it was something else like this all along.
I'm running C2 cams and a plenum spacer though.
Basically my car will make 530whp or so no matter how much boost it's running now.... Hopefully we'll find out soon if it's related...
Old Nov 19, 2007 | 12:34 PM
  #62
phunk's Avatar
phunk
CJ Motorsports
valve float could be an issue too. perhaps you have a bad valvespring? it wouldnt be a terrible idea to check it if you run thru everything else. you can check it by machining an intake port blockoff plate and tapping a hole in it for an air compressor fitting, then use a pressure regulator to push 20psi at it to make sure the valves dont push open? i have never done this before or heard of it done, but just an idea and i cant think of why it wouldnt work.
Old Nov 19, 2007 | 04:09 PM
  #63
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Do you have JWT valvesprings and retainers?
Old Nov 19, 2007 | 04:23 PM
  #64
thawk408's Avatar
thawk408
Is it throwing any check engine lights?
Old Nov 19, 2007 | 04:34 PM
  #65
taurran's Avatar
taurran
Yes, at least they were specified in the build.
Old Nov 19, 2007 | 04:50 PM
  #66
D350Z10's Avatar
D350Z10
My motor is already tore down, I will be getting an anaylsis this week so I will post the results. I have Stage 2 Cams Scott Performance, and a Crawford plenum. This time I am going wth a different piston though, and they will bore, rehone and balance the motor. I really hope its not anything to do with my valves.... I do have stock valvetrain
This thread also sounds like the same case which taurran and I have encountered
Old Nov 20, 2007 | 04:29 AM
  #67
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
It's an outside shot, but maybe a few bad sets of JWT valvesprings were shipped out.
Old Nov 20, 2007 | 05:10 AM
  #68
IIQuickSilverII's Avatar
IIQuickSilverII
long shot...
but GL
Old Nov 20, 2007 | 05:38 AM
  #69
Julian@MRC's Avatar
Julian@MRC
I just dont think you want to accept what many are telling you, and you currently may be in denial.
I would reccomend you follow the advice of several members of this forum and do the following first:
Check the cam timing
Check the ignition
Check the plug gap
Check the clearances on the motor
Do a compression test
Also I may have missed it but sometimes if the engine is not broken in yet the rings will not seat under higher boost levels.
Good luck.
Old Nov 20, 2007 | 06:34 AM
  #70
Zivman's Avatar
Zivman
my recent build included a set of jwt springs and shims.....
Old Nov 20, 2007 | 07:24 AM
  #71
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Responses imbedded in quote
Check the cam timing How? Cipher?
Check the ignition how? Cipher again?
Check the plug gap done they are gapped to .028 inches as stated before. I did it last week
Check the clearances on the motor Wouldn't that require completely disassembling the motor? If so that's not a option at this point.
Do a compression test Already done and it came back perfect 152-156psi in all cylinders
Also I may have missed it but sometimes if the engine is not broken in yet the rings will not seat under higher boost levels. Engine has almost 4000 miles on it, it's broken in
Good luck.
Old Nov 20, 2007 | 07:34 AM
  #72
Julian@MRC's Avatar
Julian@MRC
To check the proper cam timing, your going to have to take the front engine cover off, there is no way around it..We have also seen weak/cracked valve springs in some cases,but you upgraded your springs correct?
There is most likely an issue with the motor,just accept that and start to diagnose from there.For the pwoer to fal off up top it is most likely timing related,combustion pressure loss related, or a bottleneck in the exhaust system and turbo kit design,such as the TN kits. And since your rocking an APS with dual 3" down pipes, the last one is 99.9% not the issue...
I would start simply looking at it as a weak motor, since there are no signs of it breaking up up top, correct?
It sucks, but its part of playing the game.
Old Nov 20, 2007 | 07:45 AM
  #73
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Do you know if I can check cam timing with a cipher? I have JWT valvesprings and retainers. I'm going to start with a leakdown test and if that comes back good then I'll start tearing **** apart.
Motor isn't breaking up up top at all.
  #74
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Just rain on my parade
Old Nov 20, 2007 | 07:54 AM
  #75
Kenk2's Avatar
Kenk2
Professional
Check the ignition
Check the plug gap
Good luck.
LOL!!! Had to sneak that one in there didnt ya...
Old Nov 20, 2007 | 07:55 AM
  #76
synth19's Avatar
synth19
Sorry to hear about your issues Brian, Irshad does have cipher loaded on their laptop in case you don't have it.
Old Nov 20, 2007 | 08:04 AM
  #77
Julian@MRC's Avatar
Julian@MRC
I didnt sneak anything in there..This is typical diagnosis.
Old Nov 20, 2007 | 08:23 AM
  #78
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I'm aware, but my car is "put away" for the winter so any diagnosis I do will have to be in my garage.
Old Nov 20, 2007 | 08:24 AM
  #79
96sleeper's Avatar
96sleeper
It could be valvesprings, but it sure looks like cam timing to me. The VTC's do very little after ~5200rpm if I remember correctly, and thats where your power starts to fall.
Old Nov 20, 2007 | 09:56 AM
  #80
max2000jp's Avatar
max2000jp
Friday, Saturday, and Sunday is supposed to be nice and in the 40's. If you need a hand, give me a call. I have a long weekend.
