aps tt issue question
Old Nov 21, 2007 | 05:10 PM
icedoutis's Avatar
icedoutis
Default aps tt issue question
got a quick question reguarding an aps TT install. There is a steering knuckle that the instructions say to grind down, It has been shaved down, but it still hits the turbo housing. Anyone have any insight info into this? Also, where is the wideband sensor located? Normally it's 6" downstream from the turbos, but on this application that is kinda difficult unless I want to put it on one bank only. Thanks
Old Nov 21, 2007 | 05:20 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
well what year is your car and the wide band are you talking about the pre cat 02 wideband or are you installing a aftermarket 02?
Old Nov 21, 2007 | 05:22 PM
icedoutis's Avatar
icedoutis
06 revup, innovate wideband
Old Nov 21, 2007 | 05:45 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
OOOoo wow you are in trouble with the 06, there is a very particular way you have to cut the steering knuckle its very labor intensive and hard to do i cant really get into it as for the wideband if you put it a bit farther down it really wont hurt ive seen them read accurate as far as 1 foot your best bet depending on your dp or tp set up is putting it there ive installed them in the aps 3in dp before with great results.
Old Nov 21, 2007 | 05:59 PM
icedoutis's Avatar
icedoutis
ok, thanks
Old Nov 21, 2007 | 06:06 PM
icedoutis's Avatar
icedoutis
decided to grind the turbo housing a bit, got the piece to fit. As for the wideband, I think ill just put it on the left bank. Thanks for the help in the matter.
issyz
Jul 2, 2017 03:04 PM
Depravity
Oct 1, 2015 04:49 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
