Injected Performance: Cosworth dyno test at 7000+rpm FI
Old Dec 20, 2007 | 02:57 PM
  #41
VIZAGE's Avatar
VIZAGE
It's nice and peforms well. But still not worth it IMO. Then again some paid $800 for the SSV and you all know where that got ya. I'd rather settle for a meth kit upgrade. Good job on getting the testing data out there for everyone to see.
Old Dec 20, 2007 | 03:03 PM
  #42
XKR's Avatar
XKR
How about Meth Kit amd Cosworth Plenum
Old Dec 20, 2007 | 03:12 PM
  #43
IIQuickSilverII's Avatar
IIQuickSilverII
i guess if you are n/a with stock n/a engine then its not worth it...
but if youa re Fi with build engine then you should consider it
  #44
SpoilsofWar's Avatar
SpoilsofWar
Originally Posted by XKR
I have never seen these kind of gains from a spacer
Okay, neither have I... Whats your point exactly?
The Cosworth makes 30hp over stock at $1,100. If a spacer made say 15hp over stock, at $200, then I would be hard pressed to convince myself the Cosworth was worth it. However, if the spacer only made 5hp or so, then the Cosworth is the way to go.
This is not a hard concept really... Cost / Benefit.
Old Dec 20, 2007 | 03:16 PM
  #45
westpak's Avatar
westpak
SFZCC
was the stock setup with revup lower plenum or non-revup lower plenum?
Old Dec 20, 2007 | 03:25 PM
  #46
D350Z10's Avatar
D350Z10
BUTTTTTTT
Cosworth makes power till REDLINE, so when your racing your power doesn't fall off at higher rpms.... which is a HUGE DIFFERENCE.
Also +1 on the meth kit and cosworth plenum
Old Dec 20, 2007 | 03:29 PM
  #47
VIZAGE's Avatar
VIZAGE
Only if I were a baller. But someone as myself. I would have to use the extra grand on headwork or something of that nature. The plenum game has come and gone. As the OP stated, cost/benefit ratio.
Old Dec 20, 2007 | 03:32 PM
  #48
XKR's Avatar
XKR
I maybe wrong....but didnt Hal post a dyno sheet with stock plenum vs plenum spacer and you could hardly tell which one had spacer and which one didnt, one line on top of the other
So that already tells me that that $200 would have been better spent on the Cosworth
And now they show a chart that clearly shows the Cosworth making big gains !!
BTW that was 30 - 40 "Whp" gain , not 30 "hp" gain
Old Dec 20, 2007 | 04:29 PM
  #49
doug's Avatar
doug
30-40 whp gain on a 4.2L
lets not forget a built motor with APS Extreme Kit on a 3.5L makes about 600 @ 19 PSI and a 4.2L makes about 700 @ 19 PSI IIRC ..
so you can't compare 4.2L gain with a 3.5L gain.. unless you planning to get a 4.2L
Old Dec 20, 2007 | 04:33 PM
  #50
XKR's Avatar
XKR
Doug...dont be putting my business out there ...
Doug....when this whole Plenum thing first started....most was saying that if this thing made 17 - 18 whp ...it would be worth it.....Now it shows over 20 and people are still arguing its woorth....at what minimum whp do you all think this thing would be worth the 1G?..
Old Dec 20, 2007 | 05:50 PM
  #51
meatbag's Avatar
meatbag
Looks like I will have to pick one of these up when I get some extra money.
Old Dec 20, 2007 | 05:54 PM
  #52
doug's Avatar
doug
well i am sure its worth it to some people.. people pay $2,000 for exhaust that gives 3-5 whp .. so again.. to eaches own.. personally i would spend that $1,000 on a meth kit or a Nitrous Kit.. but thats just me
Old Dec 20, 2007 | 06:03 PM
  #53
SpoilsofWar
Really? Wow! And here I thought they pulled the block and put it on an engine dyno just to test the Cosworth plenum... Silly me.
Old Dec 20, 2007 | 06:58 PM
  #54
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
You guys are jacking this thread...up!
Old Dec 20, 2007 | 07:01 PM
  #55
turismo's Avatar
turismo
Still would like to see more results. Impressive, definently!
Old Dec 20, 2007 | 07:05 PM
  #56
QuadCam's Avatar
QuadCam
+1. It would seem that the RevUP runners are designed more for 7000+ operation. I would think the Revup lower will start to find a home for some guys once people start truly building their setups for higher RPM power.
Old Dec 21, 2007 | 04:56 AM
  #57
westpak's Avatar
westpak
SFZCC
yeap, that is why I asked I went with the Revup lower plenum and a spacer and the car pulls all the way to redline (7200)
Old Dec 21, 2007 | 05:05 AM
  #58
chris'smax's Avatar
chris'smax
My car (06) with just the aam spacer keeps gaining power all the way to redline. It could be the revup lower plenum or it might be those big a$$ turbo's i have
Old Dec 21, 2007 | 06:14 AM
  #59
IIQuickSilverII
+1
there should be a different thread to compare to the motordyne products...
I have personally used them and i got no that much gaims FIed...and this plenum does look quite promisint in the top end and on...
Old Dec 21, 2007 | 06:35 AM
  #60
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Trying to keep it on topic.
I have heard this several times now. And I have heard the exact opposite just as many times from as many people. Injected just posted 15HP on their TN vehicle with a spacer. Taurran and you didn't get anywhere close to that.
If FI spacer gains sometimes happen and sometimes don't, why is this the case?
And will the same performance variability exist with the Cosworth and or Revup plenum?
What other FI variables are there that would make it sometimes happen and sometime not? Mechanical? Tuning?
IDK
Its wierd.
