Vortech: Diameter of filter on blower?
Old Jan 16, 2008 | 08:23 AM
moog's Avatar
moog
Default Vortech: Diameter of filter on blower?
I need a few people to confirm what size the opening of the Vortech blower is where the filter resides. I've heard anywhere from 3.5" to 5". Trying to get some tubing to route the filter elsewhere.
Old Jan 16, 2008 | 08:36 AM
Quamen's Avatar
Quamen
Old Jan 16, 2008 | 08:50 AM
Biochem7's Avatar
Biochem7
Regular
You will most likely need 4" b/c you need to angle the tubing downward slightly.
Old Jan 16, 2008 | 10:20 AM
Quamen's Avatar
Quamen
The inlet of the blower is 3.5".
Old Jan 16, 2008 | 10:37 AM
booger's Avatar
booger
Originally Posted by Quamen
3.5
+1
O.D. I believe
You can get the info on the Vortech site . At least you were able to a while back . Thats where i found out the T-trim was 4 inches
Old Jan 16, 2008 | 10:51 AM
Biochem7's Avatar
Biochem7
Regular
If you look at the inlet of the blower and compare it with the stock intake square opening, they are not aligned. You could get a 3.5" silicon tubing make it fit, or you can get a 4" tubing and cut the bottom portion so that you can angle the tubing downward.
Old Jan 17, 2008 | 12:00 AM
Quamen's Avatar
Quamen
I don't quite understand why you would go with a 4" since there would be no gains.
To the OP-
You can get any filter with a 3.5" opening and it will fit on the blower. I am currently using an Amsoil EA filter. With that in mind you can use aluminum 3.5" tubing if your good and make it work or you can use 3.5" silicon bends. Whatever works best for you.
Old Jan 17, 2008 | 12:06 AM
iStan's Avatar
iStan
ZR
Where is a good place to get some 3.5" silicon tubing? I remember seeing it at Summit but it was in increments of 10'
Old Jan 17, 2008 | 04:42 AM
jpc350z's Avatar
jpc350z
To the OP-
What is the Amsoil eA FILTER #??
Old Jan 17, 2008 | 04:47 AM
Blake@Braille's Avatar
Blake@Braille
Send me a PM to remind me, but I have had an S Trim and I will measure our new T-Trim kit to get you the correct measurements.
BTW - My Vortech kit with the S-Trim made 400 to the wheels stock block. We are going to tune the T Trim to see what we get soon.
Old Jan 17, 2008 | 05:42 AM
MrJax's Avatar
MrJax
Fights On!
3.5 inches on the tuner kit (SQ trim). The cheapest alternative might be to adapt the Injen CAI (like we did). It has plently of silicon couplings, aluminum tube, etc. and you can trim it to fit. The larger Injen air filter can be wedged behind the bumper brace (with a lot of grunting).
Hope that helps
Old Jan 17, 2008 | 10:12 AM
Quamen's Avatar
Quamen
Vibrantperformance also has a ton of bend in silicon and aluminum in many different sizes.
I will have to check what the part # was for the Amsoil filter I bought for my vortech
Old Jan 17, 2008 | 10:15 AM
Quamen's Avatar
Quamen
Amsoil part #EaAU3560.
However, chances are that no one else will be able to fit this filter like I can since I have a custom vortech setup and basically have unlimited freedom with room.
Old Jan 17, 2008 | 10:16 AM
iStan's Avatar
iStan
ZR
You boys in Wisconsin sure do install Vortechs funny
I'll take a look through vibrant
Old Jan 17, 2008 | 12:13 PM
Quamen's Avatar
Quamen
Yes we do!
Vibrant is the way to go IMO. Their silicon couplers are great quality and are thick to handle high boost. That is what I am using on my kit.
Old Jan 17, 2008 | 12:38 PM
eez's Avatar
eez
3.5"
lapham3
Oct 7, 2022 03:15 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
juang20
Intake
Sep 7, 2015 05:37 PM
