Best idling LARGE injector
Old Apr 25, 2008 | 05:31 AM
booger's Avatar
booger
Default Best idling LARGE injector
Shop has been tuning the new Haltech EMS for the last couple weeks . Taking his time getting to know the new EMS . Once he got to tuning in the upper rpm's [ above 6000rpm's ] he is running out of injector . He raised the fuel preasure 10 psi and then the fuel preasure started to fall off up top . So the 550's RC's arent big enough . [ FYI -walbro intank , return fuel system ]
So he may put in 750 or 850's in . What is the best idling larger injector you guys have worked with ?
THANKS !
Old Apr 25, 2008 | 06:51 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
deatschwerks 850cc injectors are my choice. they work perfectly for me.
largest drop in replacement available, plug and play...
Old Apr 25, 2008 | 07:05 AM
350z-900whp's Avatar
350z-900whp
PE 800cc i use it on my car and they work perfectly
Old Apr 25, 2008 | 07:29 AM
booger's Avatar
booger
^^^ This is what we were leanig towards right now . He'll have to wire back in the stock injector clips
Old Apr 25, 2008 | 08:18 AM
D350Z10's Avatar
D350Z10
^ if you already have rc injectors booger, get 750's I have them and they have always worked great. Idle and Start up is great
Old Apr 25, 2008 | 08:36 AM
taurran's Avatar
taurran
Yep, my car's running these. I'll let everyone know how I like them.
I had RC 750's before and am sort of indifferent to them. They were running on the UTEC and I had some warm start issues. Other than that they' weren't too bad.
Old Apr 25, 2008 | 10:21 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
I have the Rc1000 with a GTM 1K idle bump reflash and it starts right up all the time anytime (FCON).
Old Apr 25, 2008 | 10:54 AM
GTM's Avatar
GTM
Vendor - Former Vendor
As long as you go with a Denso injector you should be ok, HKS, Blitz, and PE all use Denso injectors. The PE are direct fitment without modification to your lower collector, so I would probally go with those or the Deatchwerks (if they are also a Denso, which I believe they are)
Good luck!
-George
GTM
Old Apr 25, 2008 | 11:05 AM
Crom's Avatar
Crom
The RC injectors tend to have a irregular spray pattern and are frequently unreliable....I've had some bad ones.
Old Apr 25, 2008 | 11:47 AM
sentry65's Avatar
sentry65
the burninator
a standalone or ECU flash for injectors makes a big difference in idle smoothness and the car starting right up
Good luck!
-George
GTM
I thought Deatchwerks are bored out stock injectors?
+1 on Denso. They seem to be the best out there but also most expensive
Old Apr 25, 2008 | 12:27 PM
GTM's Avatar
GTM
I heard they are going to be using Denso injectors, but not sure.
-George
GTM
Old Apr 25, 2008 | 12:30 PM
Nexx's Avatar
Nexx
i went hks 1000cc with my haltech.. i hope to have zero start up or idling issues, which i have been told should not be a problem with this combo.
IIQuickSilverII's Avatar
IIQuickSilverII
-George
GTM
that is correct ..
nice.... your idle will also depend on the cams you go with
Old Apr 25, 2008 | 01:28 PM
booger's Avatar
booger
Im pretty sure the shop is going with the Deatshwerks and wire back in the stock clips . I left it up to him .
Thanks guys !
you confirmed that we made the right choice
Old Apr 25, 2008 | 01:53 PM
XKR's Avatar
XKR
My HKS 1000cc have a good idle....I guess the Fcon does not hurt.
Old Apr 25, 2008 | 02:18 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I agreee...stick to something Denso.....DW, PE, or HKS.
Old Apr 25, 2008 | 03:15 PM
thawk408's Avatar
thawk408
No love to Precision?
Old Apr 25, 2008 | 03:17 PM
GTM's Avatar
GTM
Nope, I have heard very bad things about those injectors, probably worse than RC. But again that is just what I have heard...
Old Apr 25, 2008 | 03:18 PM
thawk408's Avatar
thawk408
I have never personally used them, so no hard feelings . I just know that are really popular in the supra crowd.
Old Apr 25, 2008 | 03:20 PM
GTM's Avatar
GTM
Yea, They are also very popular with the EVO guys, but that is mainly because they are cheap, just like most EVO owners
-George
