More hp out of vortech
Old May 12, 2008 | 05:46 PM
turtle1678's Avatar
turtle1678
Default More hp out of vortech
Hey guys I just got my vortech on and I am looking to add a little more hp with out doing a ton of engine work what can I do?? I have a spacer headers test pipes exhaust, I though about injectors but I dont know enough about them or what size and same with a pulley can someone educate me please
Old May 12, 2008 | 05:48 PM
Nexx's Avatar
Nexx
smaller pulley, if you have the stock 3.33, that thing is garbage. get some deatchwerks 600cc injectors, 2.87 pulley, fuel pump and a utec. get a GOOD tune and you'll be around 400 to 420whp with your current mods.
Old May 12, 2008 | 06:11 PM
05Z33's Avatar
05Z33
+1^
Old May 12, 2008 | 06:12 PM
05Z33's Avatar
05Z33
How much power are putting down now, and what are your power goals?
Old May 12, 2008 | 06:54 PM
Lawy'dU's Avatar
Lawy'dU
You don't need 600cc injectors for that, or a fuel pump. Stock injectors are good to make at tops 440whp. 600cc injectors are overkill in anybody's book.
Old May 12, 2008 | 06:59 PM
Floridaboy1605's Avatar
Floridaboy1605
Why not upgrade now?? better to have the duty cycle lower than higher!!!
Old May 12, 2008 | 07:10 PM
350Z400rwhp's Avatar
350Z400rwhp
I have the Detschworks 600s and they idle like stock and run perfect. I had an issue with restarting the car while hot that required me to blip the throttle on start up but now after a week the utec has figured things out and now it even starts like a stock car too.
Old May 12, 2008 | 08:20 PM
Hexxum001's Avatar
Hexxum001
I couldn't have said it better myself. This setup will get you some nice numbers without worrying about maxxing out your stock injectors. A good tune is the key however. Make sure to find someone that knows what they are doing.
Old May 12, 2008 | 08:48 PM
turismo's Avatar
turismo
+1
Old May 13, 2008 | 04:24 AM
chris'smax's Avatar
chris'smax
I have always tried to go as small as possible on injectors to avoid starting and idling issues. I would say get some RC 440's and a walboro fuel pump. If your really wanting to go for the gusto you COULD get the 2.62 pulley. That would get you around 14 psi. I am not saying this is safe, but i did it on my maxima for about a year. Also you may want to look into getting a electronic exhaust cuttout.
Old May 13, 2008 | 08:01 AM
Hexxum001's Avatar
Hexxum001
I have 550cc DW injectors and have absolutely no idling or starting issues.
Old May 13, 2008 | 08:05 AM
chaparro78's Avatar
chaparro78
+1, add a fuel return system and you good to go
Old May 13, 2008 | 10:23 AM
turtle1678's Avatar
turtle1678
Thanks for the input guys, so basically are you guys saying the vortech fuel system is garbage and to get more power I have to go with a bigger fuel pump and injectors, or can I add larger injectors on the vortech FMU, and a larger pulley and just get a good managment system and a tune?
Old May 13, 2008 | 10:35 AM
chaparro78's Avatar
chaparro78
if u looking to get more than 400hp, you will need the walbro and SMALLER pulley
Old May 16, 2008 | 07:59 AM
dimebagdolf's Avatar
dimebagdolf
When I had my Vortech I was putting down just over 420 whp and 340 lb ft.
with the stock injectors and just running the Vortech fuel system. Car ran great for about 2.5 yrs with ZERO problems. But I was running cams with the stock pulley (3.33) and wasn't relying on more/quicker boost for my power.
I think the arguements about being safe with your fuel system if you're gonna go to the 2.87 pulley are quite valid. You want to make sure you're getting enough fuel in there to keep things nice and cool.
Old May 16, 2008 | 11:11 AM
booger's Avatar
booger
420whp on just cams and the stock 3.33 pulley ???
Wow...new record !!!!
normally it takes the 2.87 pulley and at least 11-12psi , even with cams .
Old May 16, 2008 | 02:56 PM
freezeg35's Avatar
freezeg35
Some ppl run the upgraded 380 injectors because they are cheap and readily avaliable from ppl who upgrade the turbonectics kit, they are also plug and play. Come to think of it, i have a set that have less than 6 months driving on them sitting at gtm. Pm me if your interested.
Old May 16, 2008 | 03:12 PM
Pun1sh3RZ's Avatar
Pun1sh3RZ
Twin turbo
Old May 16, 2008 | 03:36 PM
superchargedg's Avatar
superchargedg
Damn Noobs
He said that cause if you ever look at his posts he dosent know a damn thing about anything.
Old May 16, 2008 | 06:07 PM
Hexxum001's Avatar
Hexxum001
^^^lol
