Fx35 PowerLab turbo kit on stock block
Old Jun 2, 2008 | 05:56 AM
350z-900whp's Avatar
350z-900whp
Exclamation Fx35 PowerLab turbo kit on stock block
Hi everyone im posting this for my friend who owns FX35 Rwd
he is considering installing PowerLab single turbo on his Fx35. but he have some questions regarding this kit
1- do you think the piping will need to modified ?
2- what would you think would be safe tune for this kit on stock block ? '' 8 or 6 psi " which he consider
3- what do you think of this kit ?
btw this his daily drive car, he is looking for a safe setting
other mods he consider with this kit
- koyo radiator
- custom oil cooler
- 1 step cooler spark plugs
- hks evc boost conrtoller
- hose kit
the turbo kit comes with :
- Garrett GT35R Dual Ball Bearing Turbo with .82 A/R Turbine
- TiAL 44mm External Wastegate (Silver Top)
- TiAL 50mm Blow-off Valve (Silver Top)
- 27"x12"x4" Front Mount Intercooler
- Polished Stainless Steel Exhaust Piping with 3" Downpipe
- Polished Aluminum Intercooler Piping
- CNC Billet Aluminum High Capacity Oil Pan Spacer
- New Custom Extended A/C Line
- Stainless Braided Oil Feed and Return Lines
- All Necessary Hardware and Installation Instructions
- 600cc (Set of 6 direct fit) Denso Injectors
- TurboXS Engine Management Unit
- TurboXS MAP Sensor
- Walbro 255LPH Fuel Pump
link:
http://intensepower.com/pogttukit350.html
thanks for your help !
Old Jun 2, 2008 | 06:15 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
The turbo piping will have to be modded a little due to the 5AT tranny. I was @ PF the other day and they were having to mod the piping do to the 5AT tranny on 1 they are almost done with. I believe it was only 1 pipe that had to be extended a little. Don't need the radiator, get a tstat. Def. need the colder plugs
Old Jun 2, 2008 | 06:35 AM
350z-900whp
u was referring to FX35 right!
Old Jun 2, 2008 | 06:43 AM
SlideFox's Avatar
SlideFox
I think some of the I/C piping will have to have minor modifications, but it should be able to be installed by any qualified tuning shop.
Wastegate pressure should be OK on stock block. (6psi)
Ahsmo's Avatar
Ahsmo
Imakecopies
call intense or powerlab?
Old Jun 2, 2008 | 06:47 AM
UMW350Z's Avatar
UMW350Z
I am doing the same setup but no hose kit or boost controller. The boost controller will be an UNSAFE MOD if you get in there and screw with the PSI without a tune to accompany it. If you don't have preset, SAFE maps, the boost controller will be the devil on your shoulder telling you 'you can beat that Z06'
My car should be done today or tomorrow, you will see a whole thread from MRC on it. Sit tight
So far, it blows away the TN kit based on the hardware.
Old Jun 2, 2008 | 06:55 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Yeah, they use the same drivetrain setup so the turbo piping should all fit except 1 that needs to be modded. As for the intercooler piping, you'll prob have to do some custom fabbing there.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
