FS: NEW 280º Tomei Cams :)
Old Jun 4, 2008 | 01:18 PM
IIQuickSilverII's Avatar
IIQuickSilverII
Default FS: NEW 280º Tomei Cams :)
Brand New . Cams located at Intense right now and they can vouche for them.
selling for 1200$ firm
Old Jun 10, 2008 | 10:23 AM
IIQuickSilverII
Bump!!!
Old Jun 10, 2008 | 11:17 AM
TTRANK's Avatar
TTRANK
Why are you selling them?
Old Jun 11, 2008 | 12:48 PM
IIQuickSilverII
without going into a whole lot of details that can get this OT, my turbo application requires me to work more on the mid range than the top end so i need lower duration cams. Plus I'm working on a sponsorship deal with a different manufacturer. Most TT builds would benefit from this cams specially if they wanna think about making power on top end and raising the rev limiter specially as you raise the psi levels .
This cams are brand new, never installed.
Old Jun 11, 2008 | 01:38 PM
r0mey's Avatar
r0mey
moved since other FI regs have posted for sales in FI
Old Jun 11, 2008 | 04:21 PM
IntenseSales's Avatar
IntenseSales
Vendor - Former Vendor
Big ups and Bump for some BIG BOY Cam"Z"
GL with the sale "*****"ge
Free Intense Sticker for the one who swoops up these cam"Z" haha... srsly!
Old Jun 17, 2008 | 05:49 PM
IIQuickSilverII
Old Jun 28, 2008 | 01:03 PM
Frostydc4's Avatar
Frostydc4
Question
Can these be used with stock pistons or will the valve reliefs have to be modded?
Old Jun 28, 2008 | 03:57 PM
IIQuickSilverII
ill have to check but i believ you can need to use something like this
http://www.intensepower.com/jimwotevqvas.html
Old Jun 29, 2008 | 08:41 AM
nismology1's Avatar
nismology1
Stock valve reliefs need to be deepened by 1mm at the very least.
Old Jun 30, 2008 | 03:12 PM
Frostydc4's Avatar
Frostydc4
Can this be done without removing the pistons from the motor?
Old Jun 30, 2008 | 09:00 PM
SlideFox's Avatar
SlideFox
Yes
Old Jul 29, 2008 | 05:46 PM
JAM3Z's Avatar
JAM3Z
Phenom
Bump for a good seller.
Old Jul 29, 2008 | 06:22 PM
IIQuickSilverII
Old Jul 29, 2008 | 07:03 PM
rednezz's Avatar
rednezz
Dang I only need a pair not all four.
They should work but you should clay it to make sure everything clears to be on the safe side. The 272's work without any issues.
Old Jul 29, 2008 | 07:05 PM
IIQuickSilverII
some one put that stimulus check to good use
Old Jul 29, 2008 | 07:15 PM
nismology1's Avatar
nismology1
With stock pistons? Aftermarket pistons usually feature extra-deep valve reliefs.
It also depends on which 272's you're talking about since Tomei also makes 272's with 10.5 mm lift. But according to them, the stock reliefs need to be deepened when used with their > 11mm lift cams.
Old Jul 30, 2008 | 11:22 AM
__jb's Avatar
__jb
Z + Rear Seat
Originally Posted by SlideFox
Yes
While it might be technically possible, I wouldn't say it is feasible or desirable.
It would throw the rotating balance off and also be very likely to get chips from the flycutting into the engine... plus, I think it would be pretty difficult to set up.
Have any of you actually done this?
Old Jul 30, 2008 | 12:01 PM
SlideFox's Avatar
SlideFox
I haven't personally done it, but I have seen it done.
Old Jul 30, 2008 | 12:12 PM
rednezz's Avatar
rednezz
Will you sell just a pair?
