Vortech Kit for NON REVUP
Old Jun 19, 2008 | 01:30 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
Default Vortech Kit for NON REVUP
Hey Guys,
I searched before I asked and I know its been asked I just couldn't find the thread.
I have the opportunity to get a Vortech for non revup. I am wondering how much will I need to spend with vortech to make it fit my 06 revup.
Thanks for your advice
Old Jun 19, 2008 | 01:51 AM
teh215's Avatar
teh215
At a minimum the mounting bracket is different. Good luck finding one other than from Vortech which will probably run $400+.
Old Jun 19, 2008 | 01:58 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
shucks thanks for the tip
Old Jun 19, 2008 | 04:43 PM
atomevolution's Avatar
atomevolution
Cheapest is $579 iirc.
Old Jun 19, 2008 | 10:58 PM
MrJax's Avatar
MrJax
Fights On!
Rev-Up kit has a different pulley. It comes with the 3.12 instead of the 3.33. Are you planning on using a UTEC or Haltech EMS? The Split Second box on the non-Rev-Up will not work on the '06 ECU (or so I have been told). The FMU may not be sufficient, either.
All told, you might be better off getting a tuner kit for an '06 then adding the fuel pump, injectors, and UTEC rather than buying a new bracket, pulley, and FMU/EMS system for an earlier Vortech.
Old Jun 19, 2008 | 11:45 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
i dont think the tuner kit is carb legal i hate california
Old Jun 20, 2008 | 03:16 AM
MrJax's Avatar
MrJax
Fights On!
Yes, I think you're right. It's a shame too, since a tuner kit with all of the right equipment and tuned carefully would be just as 'clean' as Vortech's setup and probably more powerful.
Isn't there a waiver program where you can get a custom set-up tested and CARB certified? If so, that would almost certainly be more expensive and bothersome than going with the standard kit.
Good luck.
Old Jun 20, 2008 | 01:12 PM
teh215's Avatar
teh215
MrJax - Where'd you mount the catch can?
Sorry for the OT.
EnjukuRacing
Sep 30, 2015 06:55 AM
