????? No spark
Old Jun 22, 2008 | 01:34 PM
JS04's Avatar
JS04
Default ????? No spark
Ok, just finished up everything on the TN install. Tried starting the car but its like the car isn't getting any spark. I already checked everything TN said do in the instructions. All thats good. Tried doing the throttle body reset since I had it unplugged. But that doesn't seemed to be working. Is there any special trick to get that to work?
Old Jun 22, 2008 | 01:51 PM
wannabuy350z's Avatar
wannabuy350z
when u changed your injectors, did you change your plugs as well?
maybe your coils are disconnected.
are you running the ECU reflash by T-netics
Old Jun 22, 2008 | 02:17 PM
JS04's Avatar
JS04
^^^Nah, Im running a UTEC. I changed my spark plugs too but they're all connected.
Old Jun 22, 2008 | 04:14 PM
JonnyC's Avatar
JonnyC
Long shot, but I disconnected wire clips around my ignition when I was doing my wiring install and forgot to hook it back up, which caused the immobilizer to kick in and prevent spark. I cranked that thing over so many times before realizing it :-/
Old Jun 22, 2008 | 04:20 PM
Jay'Z's Avatar
Jay'Z
long shot but make sure you have the correct wire connectors to the proper coil..
6, 5
4, 3
2, 1
Old Jun 22, 2008 | 05:37 PM
JS04's Avatar
JS04
I made sure the coils for the plugs were installed in the right order. Just layed them next to where they go when the spark plugs were installed. I'll have to check the wires for the ingnition even though I just pulled the dash away but never go to pulling away any wires. Also I noticed that when I put the ingnition to on the high pitch noise you hear when the throttle body is getting a signal is no longer present.
Old Jun 22, 2008 | 06:31 PM
Jay'Z's Avatar
Jay'Z
When you turn the key have you tried blipping the throttle for **** sakes??
Old Jun 22, 2008 | 06:42 PM
JS04's Avatar
JS04
^^^It doesn't do anything. Car trys to crank but the ignition isn't firing. I wonder if my key just lost its programing due to not being used for almost 2 months.
Old Jun 22, 2008 | 06:45 PM
Jay'Z's Avatar
Jay'Z
No thats not it (key wont do that)......... So your telling me you push clutch in/turn key/blip throttle at least once?
Old Jun 22, 2008 | 07:28 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Have you tested for spark, or are you assuming there is no spark.
Old Jun 22, 2008 | 08:16 PM
wannabuy350z
blown fuse?
bad starter?
just throwing it out there
Old Jun 22, 2008 | 10:20 PM
JonnyC's Avatar
JonnyC
You'll know if it's a key/ignition problem. When you turn the car to "ON", you'll see the security led lit. That means that the ignition is immobilized, if I remember correctly. If the light isn't on, then you should be fine.
Old Jun 22, 2008 | 10:25 PM
JS04's Avatar
JS04
^^^I checked it recently. Light isn't on. I remember when my throttle body went out. The car did the samething. It would crank all day long but there was no ingnition. I had my throttle body unplugged for a lil while. Like I posted earlier, I plugged the throttle body back in and tried doing the reset but the valve is not moving at all. The car will still crank but thats it. Everything else is fine.
Spork's Avatar
Spork
Get a spark tester. That's a given.
Check coil pack connections. Double check to make sure everything is wired into the UTEC correctly. Make sure the UTEC has power. I'm assuming you changed to new (colder) plugs since you went FI, so rule out faulty spark plugs.
In case you do have spark...
When you turn the key to ON, but don't start, does your fuel pump prime? You'll hear the low hum noise. Did you install new injectors correctly and wire those up at all or correctly?
If you are really in for a quick sign of spark... Take all the plugs out... Put a tiny bit of gas in each cylinder, reinstall spark plugs and everything, then try starting the car again. If it starts, you have spark.
Old Jun 22, 2008 | 10:38 PM
JS04's Avatar
JS04
^^^^Utec has power. At first I thought it was the fuel pump. Got a walbro a few months back...it was bad right out of the box. It would prime but sound like it wasn't pumping fuel. Car wouldn't start. Pulled off fuel hose and there was no fuel. Did the samething with this new one but fuel came out of the hose. So I know its not the fuel pump this time. New injectors were put in. Completly plug and play, didn't have to re wire anything. Its just really strange.
Old Jun 23, 2008 | 08:11 AM
JS04's Avatar
JS04
Took a quick vid.
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://img.photobucket.com/player.swf?file=http://vidmg.photobucket.com/albums/v36/jsmsmalley/0623081104.flv">
Old Jun 23, 2008 | 09:15 AM
captj3's Avatar
captj3
Check the connections on the utec and the throttle body. Maybe something iisn't pushed in all the way.
Old Jun 23, 2008 | 09:19 AM
JS04's Avatar
JS04
Checked the throttle body connection. Its defintley in all the way. Thinking about disconnecting the utec. Since the ecu is plugged into it.
Old Jun 23, 2008 | 02:33 PM
Spork's Avatar
Spork
Is there a way you could plug in the OEM ecu just to see if it starts?
Old Jun 24, 2008 | 09:13 AM
JS04's Avatar
JS04
Tried connecting the utec to a laptop. Utec wouldn't connect. Disconnected it from the ecu. Car fired right up. WTF? I wonder why the utec isn't connecting. A few weeks ago it would connect to my laptop no problem. Hadn't done anything different. I'm glad the car cranked up but now it idles horribly.
Dr.Paulyy
Jul 29, 2019 07:45 AM
RyansZ33
Sep 15, 2015 05:54 AM
PhiTauZ
Nov 9, 2005 12:49 PM
