Idling high...vac leak?
Old Aug 7, 2008 | 07:33 PM
diwun67's Avatar
diwun67
Default Idling high...vac leak?
I figured I'd post this here because I'm out of ideas. My car right now is idling at ~1200rpms when it's fully warmed up and will idle a bit lean, often hitting low 15 AFR's. Cruising is fine and smooth in the 14's. According to my wideband it gets pretty rich closer to redline @ WOT, around low 10's and I know the car was tuned for low 11's. EMS is a UTEC. Could it be a bad PCV?
Old Aug 7, 2008 | 09:05 PM
Weqster's Avatar
Weqster
VAC leak will cause low/bumpy idle.
Old Aug 7, 2008 | 09:09 PM
Cannysage's Avatar
Cannysage
not on my z, but on my truck, throttle kept sticking at high idle, so I disassemble the throttle body unit and lubed it back to normal. and yeah.. leaks will give you low idle. Is your temp normal?
Old Aug 8, 2008 | 04:56 AM
diwun67's Avatar
diwun67
Yeah temp is normal, has never overheated.
Old Aug 8, 2008 | 02:36 PM
superchargedg's Avatar
superchargedg
Damn Noobs
A small vac leak can cause a high idle.The best way to find it is get some carb cleaner and spray it around all vac hoses..intake..throttle body etc to find it.
Old Aug 8, 2008 | 05:54 PM
DanielW's Avatar
DanielW
does it rev between shifts when your foot is off the gas?
Old Aug 9, 2008 | 08:30 AM
diwun67's Avatar
diwun67
No, just stays at 1200
Old Aug 9, 2008 | 12:02 PM
SmallTuner's Avatar
SmallTuner
i had that problem befor and it was the throttle body
i got a new one and its fine now
Old Aug 10, 2008 | 06:33 AM
diwun67's Avatar
diwun67
Perfect...
Old Aug 11, 2008 | 02:28 PM
diwun67's Avatar
diwun67
I thought about this today and it can't be the problem. A bad TB wouldn't cause my idle to go lean.
At times at idle while at a red light it will get so lean 17:0+ that the engine will start stumbling and stuttering and then go right back to 15:0
Old Aug 11, 2008 | 02:50 PM
turtle1678's Avatar
turtle1678
Did you check your Plenum bolts, mine came loose and caused a leak a huge leak the same thing happened RPMs went crazy
Old Aug 11, 2008 | 03:50 PM
superchargedg
Damn Noobs
Mine does the same thing but only on initial startup.....then it goes away and never comes back.
Old Aug 11, 2008 | 03:52 PM
diwun67's Avatar
diwun67
Yes I did, and I figured since I was gonna loosen/retorque the bolts I might as well throw a polished one in there, so I did. Put it on, torqued to spec, problem still there. I think I'm gonna try the carb cleaner thing next. If that doesn't work, back to the shop it goes
Old Aug 11, 2008 | 08:00 PM
turtle1678's Avatar
turtle1678
you should also clean your MAF sensor that could do it too
Old Aug 11, 2008 | 08:01 PM
diwun67's Avatar
diwun67
Now THAT is a good idea, thanks What should I clean it with?
Old Aug 11, 2008 | 09:30 PM
Zstealth's Avatar
Zstealth
sorry for the noob question what is a maf sensor and where is this located? thanks.im getting the same problem rpm is going crasy like im not even feeling any power on my z its just like reving when im on 2 and 3rd gear?thinking about a leak on my muffler or maybe my nismo intake?
Old Aug 12, 2008 | 02:37 PM
jining's Avatar
jining
Go to the dealer or find someone with a consult II/III and do the idle air volume learning? Maybe that would help. Or since you have utec perhaps you need to mess with the values in the 0 column since you dont have stock injectors they need to be set to some number in the negatives.
Old Aug 12, 2008 | 02:40 PM
jining's Avatar
jining
Mass Airflow Sensor, its on the intake tube, if you look on the intake tube you should see a rectangleish box with a wire harness plugged into it. Its attached with 2 screws, torx I believe. Dont touch the wire ^_^ clean it with a spray to clean electrical parts, im sure you can get it at an autoparts store or radioshack.
Old Aug 12, 2008 | 03:40 PM
turtle1678's Avatar
turtle1678
Advanced auto sells mass air flow cleaner its like $5 just let it dry good and hold it by the plastic, be careful they are like $300 or more to replace, its always a good place to start, and Disconnect the battery, if you dont you could throw a code
Old Aug 13, 2008 | 03:12 PM
diwun67's Avatar
diwun67
I got the CRC MAF Sensor cleaner today and cleaned it when I got home. I let it dry a while, put the sensor back in and the rough, high idle is still there. I knew it would've been too easy of a fix
