jwt
Old Aug 31, 2008 | 08:17 AM
rory's Avatar
rory
Default jwt
hey guys i got my twins installed and tuned and made around 330 ish hp,tq 6psi, 440cc, utech, greddy exhaust with cats should of got test pipes. no gauges just a turbo timer. so if any1 want 2 meet up and check it out hit me up. simi valley
Old Aug 31, 2008 | 08:22 AM
frankie945's Avatar
frankie945
Enjoy the Boost...
Old Aug 31, 2008 | 08:33 AM
XKR's Avatar
XKR
Old Aug 31, 2008 | 09:28 AM
rory's Avatar
rory
can some1 host it its 1.5mb???
Old Aug 31, 2008 | 09:47 AM
frankie945's Avatar
frankie945
Just resize the photo's it's easy upload them to photobucket copy link...
Old Aug 31, 2008 | 10:19 AM
z350boy's Avatar
z350boy
330 whp sounds a little underpowered. You should be in the 360-420 range.
Old Aug 31, 2008 | 11:19 AM
DanielW's Avatar
DanielW
not at 6psi on the 530's
Old Aug 31, 2008 | 11:54 AM
wannabuy350z's Avatar
wannabuy350z
what dyno
Old Aug 31, 2008 | 02:08 PM
superchargedg's Avatar
superchargedg
Damn Noobs
The torque sounds awfull low cause i am also a auto but my greddys put me at 396rwt at 9 psi on a dynodynamics dyno.And at 5.5psi i was at 351rwt so i dunno whats up with the tq reading.
Old Aug 31, 2008 | 02:10 PM
rory's Avatar
rory
what should i do
Old Aug 31, 2008 | 02:14 PM
rory's Avatar
rory
it was all done at gtm. sam tuned it. it has cats. he said he can get a little more with test pipes and another tune but still this is so much money.
Old Aug 31, 2008 | 02:22 PM
rory's Avatar
rory
dyno
Old Aug 31, 2008 | 02:34 PM
rory's Avatar
rory
Default jwt twin turbo
hey guys i got my twins installed on my 6sp and tuned and made around 330 ish hp,tq 6psi, 440cc, utech, greddy exhaust with cats should of got test pipes. no gauges just a turbo timer. so if any1 want 2 meet up and check it out hit me up. simi valley
Old Aug 31, 2008 | 02:35 PM
rory's Avatar
rory
its a 6sp not an auto.
Old Aug 31, 2008 | 03:03 PM
frankie945's Avatar
frankie945
you need more fuel for one, get some larger injectors, and what kind of EMS are you using?
Old Aug 31, 2008 | 03:53 PM
rory's Avatar
rory
440 and utech
Old Aug 31, 2008 | 03:57 PM
UMW350Z's Avatar
UMW350Z
mmm i bet you don't have hot start issues with the 440....my 600's give me UTEC hot starts
Old Aug 31, 2008 | 04:24 PM
wannabuy350z
you either have bad compression or your tune is super bad.
I put the 530's on my car and no tune, cats and i got 368TQ 349HP.
put test pipes and do a retune, maybe your timing/ignition is super conservative. and test pipes will yield you 20WHP
Old Aug 31, 2008 | 06:28 PM
terps's Avatar
terps
wow, come on gtm does good work. my aps single puts down 330 at 6psi and 370 @9. I would venturw to guess the 530's are not at peak efficency @6 psi. the cats will lower the power and I second the bigger injectors for higher boost tunes. regardless congrats. 330 just isn't what it was a year or two ago but its still 100 more hp.
Old Aug 31, 2008 | 06:31 PM
terps's Avatar
terps
oh what exhaust are you running. I gain 40tq when I would open the cutout. the hp stayed the same but increased tq a lot. the cats will def. affect the tq number
