steering mount gauge pod...anyone using it?
Old Mar 15, 2011 | 09:42 PM
BabyZiLLa's Avatar
BabyZiLLa
Originally Posted by Kwame@z1Auto
Much appreciated. What did you have to do in terms of modifying to get the pod and gauges to fit "well"?
It's been quite awhile mate..
I remember it was a little finicky though. Guages definitely have to be electric as you don't have a lot of depth to play with.
I'll go pop one out tommorow and it'll jog my memory.. I remember I had trouble with the right one looking flush, but got it in the end.
It was nothing major though. I'm not terribly handy when it comes to fabrication and things of the sort so If I could do it, I'd say anyone could.
It is definitely possible to get a nice flush finish though. Don't let some of those "ATi Pod sucks" threads scare you off.
Old Mar 15, 2011 | 09:46 PM
BabyZiLLa's Avatar
BabyZiLLa
Originally Posted by Sylvan Lake V35
Anyone have any pictures of one in a G35?
Gord, terrible pic but try this.
http://g35driver.com/forums/interior...-epod-ati.html
Old Mar 16, 2011 | 03:56 AM
rh_334's Avatar
rh_334
This is the only pic i have right now, everyone was right about they have to be shallow gauges, but fit perfectly with my Innovate WBs, Since its really designed for a Z you cant see below ~25mph and above 7.2krpm which isn't a problem for me.
Old Mar 16, 2011 | 05:55 AM
Kwame's Avatar
Kwame
Thanks for the info.
Old Mar 16, 2011 | 06:21 AM
deanfootlong's Avatar
deanfootlong
if you havent already purchased gauges; id highly consider a zeitronics display. i love mine. displays everything i need. i mounted it right on top of the steering in the factory gauge cluster. others cant really see it.
Old Mar 16, 2011 | 06:38 AM
BabyZiLLa's Avatar
BabyZiLLa
You also wont be able to use the trip meter reset button. It get's blocked off.
But really I never use that.
Old Mar 16, 2011 | 06:40 AM
Sylvan Lake V35's Avatar
Sylvan Lake V35
G]
That's what I wanted to see I. Just wanted to know how much of the cluster was blocked. I also have the 2 innovate gauges I would like to put there. As most of you know they are very thin so they would be the easiest to make fit.
Old Mar 16, 2011 | 07:12 AM
rh_334's Avatar
rh_334
its not completely blocked, i have reset it, but it definitely is hard to get to
Old Mar 16, 2011 | 07:15 AM
rh_334's Avatar
rh_334
i was worried about that too at first, but then i remembered i have over 100k miles and its much nicer looking at the shiny gauge then 100k+ odo
Honestly when i first installed it everyone was like "thats stupid, you cant see your speed" etc, but after they sat in it most changed their minds and liked it, it very convenient place for AFR gauges.
Old Mar 17, 2011 | 07:07 AM
Sylvan Lake V35
It looks like you cant see your RPM past 6500? Is that the case?
Old Mar 17, 2011 | 07:20 AM
rh_334's Avatar
rh_334
no its more like 7200-7300+, I shift @7k and have no problem seeing it, its just the angle of that pic. That pic wasn't intended to showcase the gauges, it was right after my 3.3VLSD swap so the pic was taken with the cam resting on the steering wheel, at a much lower angle than you sit. Ill try to take a better pic this weekend and post in here.
Old Mar 17, 2011 | 07:21 AM
rh_334's Avatar
rh_334
Im shocked no one has commented on my gas gauge yet
Old Mar 17, 2011 | 07:34 AM
binder's Avatar
binder
how many times does the gauge gauge just drop instantly and you need to be able to see it in the blink of a moment? never
You can just crane your neck around and check the gas gauge one time when you get in the car and you're done. I could drive my car without a gas gauge just like i drive my motorcycles that have no gas gauge. You just watch how many miles you have driven on that tank of gas.
Old Mar 17, 2011 | 07:40 AM
rh_334's Avatar
rh_334
i was referring to the fact that in my pic my gas gauge is beyond empty
the day before that pic i got alot of wheel hop at the drag strip and knocked off the wire going to the sending unit
edit: and as far as the "How to: Drive your car without a gas gauge" I know all about that it was 3weeks before i had a chance to fix it
Old Mar 18, 2011 | 05:24 AM
Cass007's Avatar
Cass007
STOP IT Gord!! Too much of the tach is blocked IMHO. Go with XKR's setup.
Old Mar 18, 2011 | 05:31 AM
stein's Avatar
stein
Blocks too much, Too obtrusive IMHO and yes get some gas
Old Mar 18, 2011 | 05:48 AM
rh_334's Avatar
rh_334
Originally Posted by stein
yes get some gas
Old Mar 21, 2011 | 06:49 AM
  #38
Gingervitis526's Avatar
Gingervitis526
This is what I use for right now. Wideband, boost and EGT all on one display in the cubby.
[IMG][/IMG]
Old Mar 21, 2011 | 07:38 AM
  #39
ETZ's Avatar
ETZ
Default ATI Pod
I have them,like them so far. Fit not 100% but I'll work on that. Using Glow Shift gauges.
Replacing the fuel psi gauge with a boost psi
Attached Thumbnails steering mount gauge pod...anyone using it?-gauge-pod.jpg
Old Mar 21, 2011 | 08:05 AM
  #40
dikspiel's Avatar
dikspiel
Chestons Toilet
This looks nice:
http://www.brockwayengineering.com/dgauge.html
