Weird Whistle On BOV?
Old Sep 29, 2008 | 08:07 PM
aguita's Avatar
aguita
Default Weird Whistle On BOV?
Recently when im driving the TT I heard a Whistle when I go off the throttle..I think is comming out of the BOV which is a Greedy SSV..could this whistle comes from there or maybe a leak on the WG?
Old Sep 29, 2008 | 08:20 PM
SpoilsofWar's Avatar
SpoilsofWar
Greddy... And they dont make the SSV, HKS does.
And a whistle when you let off the throttle, coming from the BOV, is exactly what you're supposed to hear... I am having a hard time taking this question seriously, but maybe this is your first experience with an FI vehicle or something?
Old Sep 29, 2008 | 08:26 PM
aguita's Avatar
aguita
I meant not the BOV sound when going on boost..I mean when Im on vac and you let the throttle there is this whistle sound which I have never heard,Is not like the sound of the Vortech when not on boost...is when I apply little throttle and let off it whistle..and sorry Is a Greddy Type RS..
Old Sep 29, 2008 | 08:31 PM
SpoilsofWar
Ah, okay, I was confused by your wording.
My bet would be a vacuum leak somewhere, probably a small one and probably pre-maf if the car is running normally.
Old Sep 29, 2008 | 08:41 PM
aguita's Avatar
aguita
Sorry for my Spelling..English is not my primary language..I had a Similar Whistle and was a Leak on the Gasket of the Waste gate..but I fixed that and now im having this annoyin whistle comming form the left front fender where the BOV is..The car is running like a champ it holds its boost and everything seems normal..I guess I should Tight every clamp once again to see if the sound goes away..
Old Sep 30, 2008 | 06:19 AM
Fluid1's Avatar
Fluid1
Check the fittings on each end of the BOV. I'd also check to make sure the spring isn't getting stuck
Old Sep 30, 2008 | 09:29 PM
aguita's Avatar
aguita
hmm thanks for the response..if the spring is getting stuck what can I do to remedy this???some ligh grease??
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
